Need help with no spark on 1996 Altima.. Sat for 4 years - Nissan Forum
post #1 of 7 Old Jun 4th, 2011, 09:11 PM Thread Starter
Hello everyone. I recently came into possession of a 1996 Nissan Altima GXE. The car hasn't been touched or started since 2007, and has been sitting outside all that time. To my understanding the car was running when it was last used, so im not sure what could be the issue.
The problem i am having is the car will not start. It cranks but doesn't fire. The fuel pump is working and fuel is getting to the injectors, and power is also at the injectors. There is no spark at the plugs or coil, but the connector going into the coil does have power. I replaced the coil but it didn't do anything. I was thinking maybe the ignition control module, or crank position sensor could be bad but Im not sure where they are located on this vehicle.
Any hep would be greatly appreciated.
Mgg4591 is offline
post #2 of 7 Old Jun 4th, 2011, 09:29 PM
Sup Mod keeping the peace
rogoman's Avatar
The power transistor and the crank position sensor are all built into the distributor. The condenser is a separate unit next to the distributor. New distributors are very expensive. Get the old one tested or pick up a used one at a junk yard.
KA-T for life, yo!
rogoman is offline
post #3 of 7 Old Jun 4th, 2011, 10:08 PM Thread Starter
I was reading around that oil gets onto the pickup of the sensor and can cause this issue. If so, would pulling the distributer and cleaning the sensor do anything, or does it have to be replaced?
Mgg4591 is offline
post #4 of 7 Old Jun 5th, 2011, 07:13 AM
rogoman's Avatar
Yes, oil can get into the sensor area. Try pulling the dist and cleaning it.
KA-T for life, yo!
rogoman is offline
post #5 of 7 Old Jun 5th, 2011, 10:57 PM Thread Starter
I pulled the distributer and put it back in and it started. Its starting hard though, and doesn't always start up, so im gonna pick up a used distributer. Lightly tapping the distributer with a hammer while cranking the engine is the only way it will start. The car also doest shift past 2nd gear, and it slams hard into 2nd from first. I knew about this problem before i got the car, so its not a big deal. The other thing is i scanned for codes and came back with P0100 and P0340, which seem to be the cam sensor malfunction.
Im gonna pick up a tranny from the junkyard as well as a distributer and everything should be good. Got the tranny just about all the way out, just have to remove the torque converter to flex-plate bolts and it should fall right out.
Mgg4591 is offline
post #6 of 7 Old Jun 6th, 2011, 12:56 PM
rogoman's Avatar
The P0100 code is a malfunction of the MAF; check the harness connector. The P0340 is indeed a malfunction of the camshaft position sensor.
KA-T for life, yo!
rogoman is offline
post #7 of 7 Old Jun 6th, 2011, 12:58 PM
Super Moderator
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
auto zone has distributors for about 160 with lifetime warranties.
I'm Jeff's Daddy.
Asleep is offline
  Nissan Forum > Altima/Stanza > U13 1993-1997 Altima
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
