Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Feb 29th, 2008, 01:24 PM   #1 (permalink)
rod_88
rod_88's Avatar
engine coolant leak
k, so my engine ia leaking anti-freez, but IDk from the exact point. Its from behind the headers heat shield. is it the pump or hose? Any Suggestions?
I think i can>_<!
'95 Altima GXE(Bosch Dual Irridium Spark Plugs, Bosch Wires,K&N Air Filter, Khumo Exta 711 tires)
'76 Chevy Blazer 4x4(Lifted 4 inches, rebuilt engine, rebuilt tranny, 15inch white steelies wrapped in Nitto desert track ATs)
rod_88 is offline   Reply With Quote
Old Feb 29th, 2008, 02:25 PM   #2 (permalink)
Edog1382
Send a message via AIM to Edog1382 Send a message via MSN to Edog1382
same problem
Anyone know whats going on? I cant seem to find where the leak is coming from. I KNOW im leaking, because I see drips when I park. And I have gone through a GALLON of coolant in the last month.
Edog1382 is offline   Reply With Quote
Old Feb 29th, 2008, 07:05 PM   #3 (permalink)
glynka
Check the little elbow hose in front of the engine[bypass hose]if you have the original [factory]wire clamp chances are you have a little leak,and you can't see because run to behind the exaust manifold cover.
glynka is offline   Reply With Quote
Old Mar 5th, 2008, 01:09 PM   #4 (permalink)
rod_88
rod_88's Avatar
Sweet dude, thanks glynka
I think i can>_<!
Old Mar 5th, 2008, 06:43 PM   #5 (permalink)
Edog1382
So... I found out it WAS the water pump that was leaking! I took it in today and got it fixed. I figured it was worth the money... instead of my headache trying to fix it myself. They also replaced the belts and finally found out where my oil leak was coming from... the oil pressure switch! So... if your car is leaking oil also... it could be the switch! Thanks everyone and good luck to you!
