Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Aug 30th, 2007, 09:04 AM   #1 (permalink)
fedorafans
how to reset check engine light?
hey guys, the check engine light in my 97 Altima went on after a dead battery replacement, I already doubt checked the gas cap and i am sure it has no problem.
I think the reason is the battery replacement, so what procedure should I take to turn off or reset the check engine light?
Thanks!
fedorafans is offline   Reply With Quote
Old Aug 30th, 2007, 02:10 PM   #2 (permalink)
dfreeman616
dfreeman616's Avatar
Send a message via AIM to dfreeman616
go to a local auto parts store like autozone, checkers, murray's, that does free obd ii scans, pull the code and have them reset it. keep track of the code, it's probably a low voltage related one, but if the light comes back on, and it's the same one, you'll know something else is going on.
94/97/98 Nissan Altima (undergoing surgery)
90 Jeep Comanche 4.0L 2wd (beater truck)
87 Jeep Cherokee 4.0L 4x4
dfreeman616 is offline   Reply With Quote
Old Aug 31st, 2007, 09:22 AM   #3 (permalink)
fedorafans
Thanks dfreeman616!
Do you think it will work that I just unplug the new battery, wait a couple of mintues, and then install the battery again?
I think doing so will also reset the check engine light, am I right?
Old Aug 31st, 2007, 05:58 PM   #4 (permalink)
spat
Nissan Fanatic
Originally Posted by fedorafans
Thanks dfreeman616!
Not on OBDII
It's much easier to travel through a maze when you have a map!
Spat
Former Nissan Tech
14yrs ASE all but AT it's a bitXX!
New career - HandyMan/Electrician - Freedom at last!!
86.5 Nissan HB D21 234K Miles
94 Nissan Altima GXE ? Miles
97 Dodge Grand Caravan 3.8L 132K Miles
64 Chrysler 300-K 2-door Convertible 63K Miles
spat is offline   Reply With Quote
Old Dec 7th, 2007, 04:37 PM   #5 (permalink)
ginsu
my g/f has a 95 altima and there is no OBDII connector on the thing. seems like it was an odd year when they were doing the switchover, and the guy at autozone couldnt even hook it up to the gizmo.
there is a port, but it doesnt look like anything I have seen. need to reset codes. saw a procedure somewhere on this board, but cant find a gizmo-based approach.
ginsu is offline   Reply With Quote
Is cracked exhaust manifold causing Check Engine Light to come on? MrSparkle Truck & SUV 20 Jul 27th, 2008 05:52 PM
re-set check engine light on 1990 axxess loudrms General Discussion 0 Nov 28th, 2006 04:00 PM
Another 'Check Engine' light question. blay Truck & SUV 5 Aug 15th, 2005 07:16 PM
MIL Check Engine Light Reset Gobae Truck & SUV 10 Jan 19th, 2005 06:30 PM
How to reset Check Engine Light on 95SE HardBody janos5303 Truck & SUV 3 Aug 10th, 2004 10:21 AM
