there is nothing complicated to it.
loosen the bolt that goes through the mount. 14mm I think.
loosen the bolt that goes through the front mount(14mm).
remove the bolts and the screws.
loosen the two bolts in the front(17mm I think). loosen the three bolts in the
rear. remove the cross bar assembly. change the mount. the mount's U should look
to the front-down direction. if the 'U' looks rear-down you will have rough gear switches.
and check your driver side mount too. if it is out of wack then your front and rear mount will go bad
in a couple of months. you have to remove batery, air filter assembly. there are bolts on the side.
you have to remove driver side wheel and unsrew them from the fender.
I don't think it's possible to change the mount without removing the crossbar.
if you buy mounts in autozone --> life time waranty. I changed them second time
for free.
