Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Jan 11th, 2006, 10:16 PM   #1 (permalink)
Ironchild
97 Altima Valve Body Solenoid Noise
Here's a doozy......had hard shifts. Per Nissan tech bulletin replaced valve body solenoids. Shifting back to normal, but, when key is turned to accessory position (just before start), I can hear a fast clicking noise coming from the solenoids. I'm pretty sure (99%) this was happening b4 replacing the solenoids. Any ideas? I work at a Nissan dealership and had the other techs scratching their heads over this. Never seen it. Fluid was flushed. No other symptoms.
Ironchild is offline   Reply With Quote
Old Jan 11th, 2006, 10:36 PM   #2 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
Try checking the grounds and the dropping resistor circuit.
Also what does the CONSULT show for readings and are there any codes?
Please let me know what you find, because I would like to find out.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Jan 12th, 2006, 10:38 PM   #3 (permalink)
Ironchild
No codes.....will check others hopefully this weekend and let you know. Thanx
97 Altima Stalls when idle used97altima U13 1993-1997 Altima 27 Aug 12th, 2007 10:33 PM
2003 Altima 2.5s engine DESTROYED from loose Power Valve Screws. lax26grad L31 2002 - 2006 21 Mar 12th, 2007 01:57 PM
'97 Altima headlights inadequate - age or design ? weekendsailor U13 1993-1997 Altima 4 Oct 28th, 2005 09:14 PM
98 Altima Problems with mpg, noise praschan L30 1998-2001 Altima 2 Oct 19th, 2005 07:03 PM
2nd gen Altima Body Kit importstylez Group Buys 0 Apr 14th, 2003 12:26 AM
