Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Dec 7th, 2005, 10:21 PM   #1 (permalink)
mcf1000x2003
Ticking sound from front suspension
Hi I bought a Altima GXE for $1300 it idles and drives great but there is a clicking sound coming from the front when i turn and it makes a grinding ype noise when i hit a bump or dip.My first thought is the CV joints or ball joints.The dealer i bought it from says they would fix whatever it is I was just curious to see what y'all think it is.
mcf1000x2003 is offline   Reply With Quote
Old Dec 8th, 2005, 06:47 AM   #2 (permalink)
LONDONDERRY
Nissan Addict
LONDONDERRY's Avatar
Sounds like your CV joints. Have them replace both because if one is bad the other one is not too far away from failing
LONDONDERRY is offline   Reply With Quote
Old Dec 8th, 2005, 07:19 AM   #3 (permalink)
Darktide
Nissan Fanatic
Darktide's Avatar
Send a message via AIM to Darktide
CV joints are more of a clinking or thumping sound while accelerating or decelerating. Not so much of hitting bumps. I did test drive an altima that had that problem. Let me know what happens as I'm pretty curious.
Darktide is offline   Reply With Quote
Old Dec 8th, 2005, 10:04 AM   #4 (permalink)
LONDONDERRY
Nissan Addict
I replaced mine last winter. Everytime I was turning I heard a clnking sound. Upon inspection it turned out the boot torn open and all that nice salt and sand they lay down the roads, penatrated and removed a bearing grease. Needless to say replacing them in the cold winter sinks. I waited until the spring to do the other side.
Old Dec 8th, 2005, 10:06 AM   #5 (permalink)
kmet
I am new, but I had the same prob with my fairly new Sentra. I took it to the dealership and they said that it was the front struts and mounts. Apparently these mounts are not the best because they immediately recognized the prob as soon as I described it. Hope that helps.
kmet is offline   Reply With Quote
Old Dec 8th, 2005, 01:24 PM   #6 (permalink)
mcf1000x2003
we had a freeze last night and for anyone thats lived in TX you know that everything shuts down so i cant get it looked at today at the car lot
Old Dec 8th, 2005, 01:52 PM   #7 (permalink)
LONDONDERRY
Nissan Addict
If your CV joint is bad, making a ticking noise, This tends to happen becuase the rubber boot is split open. To inspect this yourself, turn the wheel all the way to right, then look inside the wheelwell at the CV joint, if the rubber boot is split there's your problem, do the same for the left side as well
Old Dec 11th, 2005, 02:27 PM   #8 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
I have seen where the rubber top strut mount can cause a popping but I would start with the above recommended CV boot inspection.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Jan 7th, 2006, 10:03 PM   #9 (permalink)
ssaemployee777
ssaemployee777's Avatar
94 nissan altima GXE 117,000 mile. Cilicking sound CV
Troy
I need to replace CV axle on my 94 Altima with 117,000 miles. Does any site have step by step instructions with pics? Haynes or Chilton manuals are not very helpful.
I just replaced the o-ring on the distributer 'cause it was stalling due to oil in the distributor.
Thanks,
ssaemployee777 is offline   Reply With Quote
Old Jan 7th, 2006, 10:46 PM   #10 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
The Haynes manual has a good repair procedure for the axles. I don't know of any site that has the replacement procedure but the simplest thing to do is replace the axle or else get a factory service manual.
Troy
SHIFT_Happiness
front suspension chillow Z31 300ZX(T) 6 Aug 23rd, 2005 07:31 PM
front suspension chillow Z31 300ZX(T) 0 Aug 23rd, 2005 11:26 AM
Sound from back right suspension asleepz Z31 300ZX(T) 5 May 28th, 2004 01:48 AM
Front suspension strut list Galimba1 Suspension & Brakes 2 Apr 14th, 2004 04:35 PM
suspension "creaking" sound at low speeds kev Suspension & Brakes 13 May 21st, 2003 10:26 PM
