screeching sound when starting engine - Nissan Forum
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
post #1 of 8 Old Jan 25th, 2005, 12:39 AM Thread Starter
I just bought a 2001 Nissan Pathfinder Se. Truck runs great however, I notice a screeching sound when I start the car. The sound last for about 12 seconds then goes away. Originally i thought it was radiator, because at first i would just turn the heater off and the sound would go away. Now im realizing that does not work anymore. The screeching sound only comes on when i start turn the key and the engine starts for about 12 seconds.
Kilahchris is offline
post #2 of 8 Old Jan 25th, 2005, 12:59 AM
Could it be your belts squealing (needing tightening or replacement), or is it a different kind of sound?
DanaCat is offline
post #3 of 8 Old Jan 25th, 2005, 06:43 AM
Nissan Addict
Sounds like the fan belt. I had the same sound when I just did a timing belt change and replaced all the belts, left the fan belt a little bit loose and it screeched like crazy. Easy to tighten.
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
lewisnc100 is offline
post #4 of 8 Old Jan 25th, 2005, 08:49 AM
I Live Here
probably a belt or tensioner pulley
SPEEDO is offline
post #5 of 8 Old Jan 25th, 2005, 01:15 PM Thread Starter
did the sound your heard last for like 10 seconds and then went away once you started driving???
post #6 of 8 Old Jan 25th, 2005, 01:32 PM
As most have said "belt adjustment". There is an outside chance that you have a slight leak in your water pump. Or the pump is ready to go all together. Try some water pump lubricant if the belt tightening doesn't do it.
Will is offline
post #7 of 8 Old Jan 25th, 2005, 03:45 PM Thread Starter
The belts around the pulleys seem very tight to me(I was not able to budge them).
The problem only happens intermittently. Once in every 5 times i start up my pathfinder??
post #8 of 8 Old Jan 25th, 2005, 04:49 PM
Nissan Addict
aaronford's Avatar
Sounds like your alternator belt. Turn on your heater blower and headlights before starting car in the morning, rev it a little. If it does it, you have found it.
Aaron Ford
95 2WD Nissan PU E
2002 Oldsmobile Intrigue GX
"The hard part about playing chicken is knowing when to flinch" Scott Glenn in The Hunt for Red October
aaronford is offline
  Nissan Forum > Truck & SUV
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
VQ35DE in a S13??? toddk S13 240SX 1989-1994 68 Dec 31st, 2007 10:55 PM
weird sound in engine 300zxowns Z32 Chassis 300ZX 11 Jan 9th, 2005 06:41 PM
engine not starting (just a story, not a problem..anymore) Tavel GA16DE 1.6L Engine 0 Jan 1st, 2005 11:28 PM
Ticking sound from engine nyit240 B11/B12/KN13 82-90 chassis 16 Apr 21st, 2004 10:47 PM
Funny engine sound SkylineGTR B13 91-94 chassis 5 Sep 13th, 2002 01:19 PM
You may post new threads
You may post replies
BB code is On
