» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Jan 13th, 2005, 07:31 PM   #1 (permalink)
WilliamP
Unhappy Problem with Fuel Pump - '87 Nissan Pickup
I am not getting any fuel. When I dump gas in the carburator it will run. I have power to the fuel pump, fuse and power to the fuel pump relay. My book shows two wires going to the pump but there are three posts on the fuel tank. The truck was running last spring when I parked it but now there is nothing. It turns over but doesn't have gas to it. Called the garage and they said to bring it in because there are so many relays that could be involved but we're three feet deep in snow and thirty miles from the garage, and this is my plow truck. HELP!!!
WilliamP is offline   Reply With Quote
Old Jan 13th, 2005, 08:56 PM   #2 (permalink)
88pathoffroad
Moderator
88pathoffroad's Avatar
Send a message via AIM to 88pathoffroad
First off, it's TBI (throttle body injection, two injectors), not a carb. Second off, tried changing the fuel filter yet? That's a cheap and easy thing to try first. If it's that cold and your old filter had any water in it or just plain bad fuel, it could be frozen solid.
The three wiring posts going into the gas tank are positive and negative power wires for the pump itself, then you have the sending unit wire for the gas guage.
Owner of NPORA, mod for Nissan-Infiniti Forums, NissanForums.com, NissanHelp.com, AllNissans.com and VGPowered Forums
'88 Pathfinder: 6" of lift, 33x13.50 Swamper LTB's, Rancho 9000's, L&P Stage 3 steering system, K&N, Pacesetter headers and 2.5" exhaust, Lock-Right locker, 110A alty and electric fan swap, dual batteries, 700W+ worth of PIAAs, etc.
88pathoffroad is offline   Reply With Quote
Old Jan 14th, 2005, 01:14 PM   #3 (permalink)
SPEEDO
Post Freak
does it turn over? and just not start or do you just get a click?
SPEEDO is offline   Reply With Quote
Old Jan 15th, 2005, 11:39 AM   #4 (permalink)
oramey
Fuel line test
Can you pull the fuel line off and place it in a jar and turn the ignition on and see if fuel comes out of the line?
be careful not to get any fuel near the spark plug wires as you could ignite the fuel. Might want to disconnect the coil wires and then try it . but be careful.
If fuel is present then you can test the fuel pressure at that point and begin some more trouble shooting.
good luck!!
oramey is offline   Reply With Quote
Old Jan 29th, 2005, 01:55 PM   #5 (permalink)
naco
the sensors could be corroded, and also check the fuse for the fuel pump it might have blown.
naco is offline   Reply With Quote
90 Pathfinder Fuel Pump simple Truck & SUV 3 Nov 10th, 2004 03:39 PM
Help! Computer is in safe mode..87 pathfinder problem ZR_Don Truck & SUV 12 Mar 11th, 2004 12:01 PM
96 Nissan Pickup Problem w/ fuel pump? washingtonnissan New Member Forum 0 Feb 4th, 2004 07:00 PM
300zxTT Fuel Pump GA16DE Install Pics javierb14 Forced Induction & Nitrous Oxide 5 Jul 4th, 2003 03:21 AM
Fuel Pump problem PFS_200sx New Member Forum 1 Jun 5th, 2003 08:30 PM
