96 Quest with P0325 - engine knock problem - Nissan Forum
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
post #1 of 5 Old Dec 18th, 2004, 04:53 AM Thread Starter
The symtoms are the following
1) engine hesitation when driving. Usually runs good after cold start and will run good for a while. Stop by the grocery (or some errand) and restart engine will run crappy.
2) engine runs good when cold start. Let it idle for a while and it starts to hesitate as temperature goes up then dies.
3) One time I had to stop for errand. Engine ran really bad after restart - warm engine - but I didn't have a choice so I drove it without forcing on stepping on the gas. I manage to go on a long downhill. Seems like cold air blowing on the darn car helps remove the engine hesitation.
computer codes:
1) P0325 - Engine Knock Sensor
2) EGR
Work done already
1) Fixed EGR - found a hose that runs from exhaust gas to valve is burnt to ash - this should be a safety issue and should be recalled. I think the engineer who thought of putting a rubber hose to return the exhaust gas outha be hanged. replaced rubber hose - problem solved - computer code is gone for good.
2) Attempted fix for Knock Sensor problem includes -
a) check the harness per nissan manual - OK.
b) changed plugs, wires, rotor, rotor cap.
The knock sensor problem still exist but check engine do not turn on. I am still hesitant to pull the manifold out to check the knock sensor. I want to exhaust other possibilities before I do a big job for nothing.
c) Research - Found this site and saw this post. www.nissanforums.com/showthread.php?t=25223
I will check the canister this afternoon.
My thought at this point is that, if the knock sensor is shot and the timing retard is only 5 deg, the car should be running a lot better than what I am experiencing.
Anybody have suggestion? I will very much appreciate your input. Thanks in advance!
Last edited by jdevera; Dec 18th, 2004 at 05:01 AM. Reason: better presentation of problem
jdevera is offline
post #2 of 5 Old Dec 20th, 2004, 01:14 AM
Nissan Addict
Send a message via AIM to BORNGEARHEAD
Did the knock sensor actually trip the light? I have seen a lot of Nissans come into the shop with the KS code stored but not set.
93 NX2000 w/sr20ve
98 Frontier
BORNGEARHEAD is offline
post #3 of 5 Old Dec 20th, 2004, 06:52 AM
Nissan Addict
aaronford's Avatar
I have seen the KS pulled on the VG without pulling the manifold... I hope that it isn't a bad KS as they are quite pricey if I recall correctly.
Aaron Ford
95 2WD Nissan PU E
2002 Oldsmobile Intrigue GX
"The hard part about playing chicken is knowing when to flinch" Scott Glenn in The Hunt for Red October
aaronford is offline
post #4 of 5 Old Dec 20th, 2004, 07:13 AM
Nissan Addict
Is the check engine light on? If so you most likely have another code to deal with since the P0325 will not trigger the check engine.
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
lewisnc100 is offline
post #5 of 5 Old Dec 20th, 2004, 08:09 AM
Nissan Addict
He mentioned he had an EGR code also. I think that is what tripped the light. If the EGR problem is fixed, I would clear the codes/light and not even worry about the knock sensor.
93 NX2000 w/sr20ve
98 Frontier
  Nissan Forum > Truck & SUV
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Knock Sensor on a '96 Maxima maxima_nrh A32 1995-1999 Chassis 9 Mar 15th, 2010 08:13 PM
96 200 SX Idling problem zombie_327 GA16DE 1.6L Engine 1 Jul 7th, 2004 12:33 AM
engine problem..help randomwalk101 Naturally Aspirated 4 Jan 13th, 2003 10:16 PM
nissan truck engine problem. randomwalk101 Truck & SUV 3 Dec 23rd, 2002 11:32 PM
engine problem, need help pkrSE-R SR-Series Engines (DE/VE) 10 Aug 16th, 2002 07:31 PM
You may post new threads
You may post replies
BB code is On
