Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Dec 8th, 2004, 06:11 PM   #1 (permalink)
dnanorton
98 frontier misfire and evap problem
I have a 98 frontier 4x4 with the 4cyl. The check engine light came on a few weeks back. The codes at the time were both EVAP system codes. Evaporative Emmisions Control System Pressure Sensor Malfunction, and Evaporative Vac. Solidoid Circuit Malfunction. I wrote down the codes and reset the light just to double check, and then back it came with a vengance.
Now I have still have an Evaporative Emissions control systempressure sensor malfunction, and i have a new code Cylinder 2 misfire.
Today I replaced the plugs, wires, rotor, and distributor cap. I also replaced the purge control solenoid valve which tested bad ($196.00 just for the valve,from the dealer only). Then I resset the check engine light and waited.
Yep back on with the same 2 codes, misfire cylinder 2 and Evaporative Emissions control system pressure sensor malfunction.
Any ideas would be very welcome. How does the computer detect a misfire? Why would the Evap and a misfire be related? Why would it be only on the one cylinder? etc. I'm confused.
dnanorton is offline   Reply With Quote
Old Dec 9th, 2004, 04:24 PM   #2 (permalink)
dnanorton
Still need help
just an update for anyone that can help. I did a compression check today and found 140psi on 1,3,and 4, but cyl 2 only had 75psi. I'm not burning oil, and my coolant is clean. I am betting on a burnt valve requiring a valve job.
I still don't understand what relationship all this is to the evap emissions system.
Old Dec 11th, 2004, 12:49 AM   #3 (permalink)
nozz
nozz's Avatar
Question
hey there can't say i have had that problem yet on my 98 4x4 4 babnger 80k
i was just curious as to how many miles you have on your 's .
nozz is offline   Reply With Quote
Old Dec 11th, 2004, 05:32 AM   #4 (permalink)
dnanorton
I have 107k on it now. I honestly expected more out of it before I had any major engine problems.
Anybody know a good place to get a 4cyl long block and clutch put in around the Atlanta area?
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 32 Oct 3rd, 2008 03:11 PM
SES / Nissan CEL codes LIUSPEED General Discussion 2 Aug 22nd, 2004 10:29 PM
