First, check to make sure the motor's getting power when you hit the switch. If it doesn't, check the switch itself. There should be 12VDC+ power on one side of the switch when the ignition key is on. Replace the rear window switch if it has power but does not operate the window motor. Simple electrical troubleshooting, man.
Owner of NPORA, mod for Nissan-Infiniti Forums, NissanForums.com, NissanHelp.com, AllNissans.com and VGPowered Forums
'88 Pathfinder: 6" of lift, 33x13.50 Swamper LTB's, Rancho 9000's, L&P Stage 3 steering system, K&N, Pacesetter headers and 2.5" exhaust, Lock-Right locker, 110A alty and electric fan swap, dual batteries, 700W+ worth of PIAAs, etc.
