98 Pathfinder knocking noise when engine cold
Hey this is my first post..Have a 3.3l pathfinder have almost new belts , water pump ..changed radiator fluid and ususal maintance,,,new plugs..keep oil changed every 3,000 miles with 10w30..In the last week when the engine is cold like first start it makes a knocking noise..oil is ok no leaks...I live in florida so weather isn t an issue..
after it runs for a minute or so the knocing stops..I have looked at the engine visually it looks like it is coming from the left side ..being fairly causious I hope it is not the valves starting ...should I change type of oil first or just take to my mechanic and let him put the fear in me..???? I can tguess on what it might be since it stops in a short period of time other than bad gas ..looking on the good side..Hav eput new air filter to start...\\\ It has 120,000 miles to date on odometer..thanks Mary
