» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Aug 21st, 2004, 09:54 AM   #1 (permalink)
trooper2
Question electrical problem, new battery going dead
I should have posted two different threads, I got a 93 Pathfinder, I have
put a new battery in the truck and it has lost its charge,
I checked out the charging system and it puts out 14 volts to the battery
so what gives? any suggestions on where to start looking for shorts
or does anyone know of problems that are usual to this vechicle?
thanks
Warren
trooper2 is offline   Reply With Quote
Old Aug 21st, 2004, 05:14 PM   #2 (permalink)
Warped
Here is how you can tell if you have a drain, the cheap and easy way.
1: Go buy a 12 volt test light.
2: Take the bulb out of your dome light. This allows you to leave the door open for step 5.
3: Disconnect the negative wire from the battery.
4: Attach one end (doesn't matter which) of the test light to the battery and the other to the negative battery wire. In other words, you are completing the circuit with the test light. Don't try to start the engine or turn things on as it will probably blow the test light's bulb.
5: With the key in your pocket and the engine and everything else in the off position (radio, fan switch, wipers etc), if the light comes on, you have a constant draw on the battery. To find out what is causing that, pull the fuses one at a time until you find one that makes the test light go out. Your problem lies on that circuit.
If after performing the above tests you are still unable to find out what is killing the battery, I would suggest putting your high beam switch in the high beam position (pushed towards the dash with the headlight switch turned off) and leave it there for a few days and see if you still have the problem. I've had two Nissan pickups act the very same way with me and the multifunction switch turned out to be the culprit both times. The only way I figured out what it was was because a neighbor called me and asked me if I knew that the headlights were on in my truck. Good luck
Jeff
Warped is offline   Reply With Quote
Bought new car battery last week...now its dead?!?! CaSteve J30 1989-1994 Chassis 4 Jul 8th, 2004 07:03 PM
Rear Tail lights electrical problem SentraFourplay B13 91-94 chassis 2 May 18th, 2004 03:28 PM
Tiny (?) electrical problem - 92 SE-R RED92SE-R B13 91-94 chassis 10 May 17th, 2004 01:38 PM
Help!!! Replaced Alternator and Battery...Still having charging problem Sentra_Industies GA16DE 1.6L Engine 2 Apr 7th, 2004 10:25 PM
Recommended battery DNYC B11/B12/KN13 82-90 chassis 21 Feb 4th, 2003 10:37 PM
