Hi
Im a guy from Sweden that owns a Urvan, you know the ugly highroof container
Im using it for transportation of my motorcycle when im going on trackdays through Sweden.
There isnt a repair manual in whole Sweden about the Urvan or the Z24 engine. What i know is that the Urvan and the KinCab has the same engine, but i think that several american models of Nissan uses the Z24 engine especially Z24i. Anyone knows which US models have the Z24i engine???
If someone can take som pictures of their engine would also be great help for me....Primarily i need that picture of all the hoses that are connected around the EGR valve. Theare like 7-8 hoses in that area that are connected on small pipes etc.
If anyone has a link to a pdf or maybe can email me some info on where the screws are for the air/fuel mixture, crank angle sensor cicuit, engine coolant temp. sensor circuit are located id be thankfull.
To my problem then:
I was driving on the motorway when suddenly i heard a whissling noice.
When i came home i looked at it and i saw that the Lambda sond was all trashed. First i plugged the hole and thought that the car would work as usual, cause i was going to a race track the day after.
The day after i started the car and i drove away to the race track.
Well the drive wasnt so long
The car wasnt able to go faster then 70km/h
downhill
Uphill i was forced to go on 2:nd gear cause the engine didnt have any power to go in 3:rd. Upphill speed was 30km/h.
1mph=1,6kmh
I left the car 40 km from home and i took the bike out of it and rode in the rain for 300km to the race track......was i wet or what
When i came home i bought a new Lambda and installed and thought this was it, now its ok again......NOT!!!!
I noticed that the EGR valve was broken, it was loose and plenty of air was leaking from it, so i replaced it and hoped.....but NOPE same shit as before
There are so many hoses that i had to disconnect when i took of the EGR valve and i dont remember how the were fitted before, so maybe its that, need a picture from someone to see if i put them back together wrong?
I also took the time to change all sparkplugs when i still was fixing all the other things.
I saw about the ECU diagnostics, and got 2 codes out of it no. 11 crank angle sensor circuit and 13. engine coolant temp. sensor circuit. Becasue i dont have a repair manual i dont where theese are located. I went through all connections with WD40 and managed to get rid of the no. 11 code.
No. 13 is still there.
After that i reset the ECU and hoped this would solve the problem, but NOPE again....!!!!
Still same shit.
How does the engine sound :
On idle it runs better then ever, smooth and nice
Asi give gas it kind of chokes, and starts to shake hard and irregulary.
The exhaust gases are really hot dont know if its supposed to be like that?
Also air comes out from the airintake where the air filter is located.....???
Thats what im worried most about, why does air blow out from the airintake?
Please someone help me with this cause I must get this fixed soon, and ordering a book will take me over 10 days to get here.
Before i order a book i need to know which is the best???
Im pretty good with mechanics so i dont need a beginners book. Is there any cd´s ????
Regards R
