Originally Posted by sointense
Hey all.
Have taken seat out and exposed ECU, but the unit has no knobs or lites. Is this year suppose to? 4 cylinder king cab short bed, Service engine soon lite is on steady, and did not go out after I disconnected the battery for 30 minutes. Truck runs ruff and has poor gas milage. ANy help would be GREATLY appreciated!!!
I have 97, had the same problem. There is a small screw on the side of the ecu that you turn clockwise, or something like that, anyway after doing all that, I finally had a neighbor with a computor testor. he plugged it in and came up with some fault codes, anyway, the rought running happened at cruise speeds or when I wasn't excelling or decelling, I would hold the throttle steady and the engine would miss,. anyway among the many fault codes one had ssomething to do with the E.G.R( exhaust gas recirculator)
I then unplugged the vacume hose to the EGR and the miss went away. After one trip to work and back the check engine light came back on but the engine did not miss. I am, however, still getting poor gas mileage and low power.
extech
