Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Mar 23rd, 2004, 03:12 PM   #1 (permalink)
Desmo
Problems with 01 Frontier CC....help!
Hi all,
I have had my 01 Crew Cab since new and it has just over 100k miles. I was having some valve noise (it was very wierd sound under load) or atleast that is what I thought it was so I took it to the dealer. Just got the diag and they say that all it is is the exhaust manifold. They are asking $700 for parts and labor to replace the left side...OK. So can deal with that I guess. Cracked manifold???? whatever.
While it was there I told them that my AC was not functioning as of late (it has not been used for a few months) and to please look into that. Service guy calls me and says that they can not get a ground signal from the AC and that they need to replace the ECM unit to fix the AC....OK. I CAN NOT DEAL WITH THAT.
Does this sound normal to anyone?....I did a search but found nothing about ECM's being replaced to fix an AC problem. The dealer wants $800 bucks for the ECM.
Thanks
Desmo is offline   Reply With Quote
Old Mar 23rd, 2004, 06:24 PM   #2 (permalink)
jadcock
SHIFT_into4Lo
jadcock's Avatar
Cracked exhaust manifolds and/or broken studs are very common on Nissan V-6 engines from this era. If this were a domestic brand, they'd call it faulty engineering and poor quality control. But it's Nissan, so it's "just one of those things."
I've never heard of the ECM going bad and causing the A/C not to work. I'd take it to a local garage you trust (if there's one near you) and have them check out the problem. You may also have them do the exhaust manifold replacement, likely for much less than the dealership will charge you. The A/C problem may simply be a bad ground, that can be fixed without replacing the ECM.
Jason Adcock
Always Tread Lightly!
1995 4x4 XE King Cab - 189,000 miles
1997 Cadillac Seville - 141,000 miles
jadcock is offline   Reply With Quote
Old Mar 23rd, 2004, 06:26 PM   #3 (permalink)
1997XETruck
Master Shake
1997XETruck's Avatar
Originally Posted by Desmo
...AC and that they need to replace the ECM unit to fix the AC....OK. I CAN NOT DEAL WITH THAT. Does this sound normal to anyone?....I did a search but found nothing about ECM's being replaced to fix an AC problem. The dealer wants $800 bucks for the ECM.
Sounds fishy to me. The ECU controls the A/C with a ground signal, but you won't get a ground signal if the system pressure is too low (low on freon) or too high, the a/c evaporator sensor is showing that the evaporator is frozen, or the compressor protection sensor is showing that the compressor has overheated. Of course, all of this is based on my experience with the A/C on my truck and Q45s - not specifically on your model.
It is extremely rare for Nissans to have ECU problems unless they're damaged by an accident or water leaks.
If you're technically inclined, you can download your service manual and TSBs on at www.nissan-techinfo.com with the $20 one day viewing subscription and trace down exactly what's going on and how the system works.
I'd ask the dealership what the low and high side pressure readings are for your A/C system. That'll tell us a lot...
Heath
1997 Nissan XE Truck - 133,000 Miles
1990 Infiniti Q45 - 91,000 Miles
2005 Infiniti G35 Sedan - 34,000 Miles
1997XETruck is offline   Reply With Quote
Old Mar 24th, 2004, 01:16 AM   #4 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
A common problem on Nissan Frontiers is the A/C cycling switch going bad either shutting off the A/C entirely, or failing to cycle the compressor clutch leading to it's eventual failure due to excessive system presure causing it to slip. I do not think it is the ECU causing the problem.If it is, try going to a late model salvage yard and buying a used one instead of the dealer's pricey new one. They should offer a warranty on it (30-90 days is typical and some offer a 12 month for a fee).If they do not, try another yard until you find one that does.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Why no power for the 4 Cyl Frontier..? 95G ATL Frontier 12 Jan 22nd, 2005 08:37 AM
new here...just bought a 2004 Frontier scotty Truck & SUV 12 Nov 20th, 2004 05:56 PM
Any problems? (2000 Frontier) Noahm3 Truck & SUV 4 Mar 21st, 2004 12:10 AM
2001 v 2002 Frontier oasis1968 Truck & SUV 6 Feb 19th, 2004 10:24 AM
99 Frontier no start problems Nailbomb Truck & SUV 8 Feb 17th, 2003 04:42 PM
