Hmmm... This is kinda wierd. Couple of months ago, took a trip up to Crossville, TN. For me, this involves climbing up some pretty steep grades. Had me + a buddy of mine + Dog + 250lbs of cargo = about 775lbs. When we arrived, I found that the entire rear of my Pathfinder was lightly coated with what appeared to be engine oil (ie. brown, not red). There was some oil dripping from the engine, but the oil level was fine. Now, I had just had the oil changed the day before, and the problem did not repeat itself on the (downhill) trip back. I went back to Jiffy Lube, and they were kind enough to change my oil again for free
, but they could not tell me where the oil was coming from. I have made this trip again twice more. The second time, I was unloaded, and the problem did not present itself. The third time, I was lightly loaded, and I got a very light coating. It seems that this problem only happens when the engine is under heavy load / high RPM. Now, I have always taken pains to avoid redlining the engine, and I change my oil regularly. I would like to install a trailer hitch, but now I am very hesitant.
Now, where on earth could this be coming from, and how can I fix it? Could it actually be transmission fluid? None of this sounds good.
Thanks again.
Mark
