Hi Aaron, Heath, Warren:
Being a newbie in this forum, I can be expected to do things the hard way, in the beginning, correct?
I just now sent each of you an individual e-mail reply, instead of just posting a reply with a response covering my response to all of your suggestions.
To keep this thread going, I'll try to summarize what I wrote each of you.
I double-checked the lights that were and were not working:
Working lights: Head, brake, backup, dome light in cab. The radio and wipers are also working.
Non-working lights: tail, license plate, instrument panel lights, running lights (next to head lights).
It occurred to me that all of those non-working lights are controlled by the head light and turn signal switch in the stalk on the LH side of the steering column. The middle position of that switch should turn all of these lights on, and they should all stay on if the switch is moved to the headlights-on position. Question: could this switch be the culprit? (I believe one of you indicated one of the switches might be at fault...)
Now, if I only knew how to use my multi-tester to check that switch out, I might be home free...
Any step-by-step instruction on how to use my VOM to test this switch would be greatly appreciated.
Anyway, I will be looking forward to any additional suggestions (or instruction) you can give me, so I can get this otherwise great buggy of mine going again (at night).
thanks for your help in helping me noodle this thing out!
Bob
