Power Steering Leak in pipe - replace with hose???
I have a nasty leak in my power steering pipe that goes underneath the radiator. I found the part for 150 bucks but I was thinking can this be fixed by just using a thick walled rubber hose? This is my winter vehicle and right now I removed the belt so that I don't burn out the PS pump. I may just buy the part for 150 but I wanted to know if there are any reasons not to try a thick walled rubber hose. Thanks.
Dave
1995 Nissan 3.0 4x4 Hardbody
1999 BMW M3
Dave
I'd try the rubber hose. If it leaks, get a proper replacement.
Dave
I'd make sure you have at least a knife in the vehicle with you. If the hose blows out in the middle of nowhere, you can cut the PS belt off.
Jerry
2004 Frontier, King Cab, XE, 4x1, 4-cyl, 5-spd
Can't hurt anything. You might also check with a local hydraulic shop... they may be able to weld it for you... I have also had some success at salvage yards if you have the opportunity to browse around and pull your own parts.
