Originally Posted by jerryp58
Off the top of my head, you'd need to:
- find a carb (probably with an electric choke) that'll fit that manifold (maybe from an earlier version of the engine, maybe with a manifold)
- deal with a trans kick-down cable (if automatic)
- go back to a mechanical fuel pump or maybe an electric that can be set to the sub 10psi level
- get an adapter to mate the carb to the intake if necessary
- worry about what emissions equip (pcv, air pump, charcol cannister, etc.) may be required (if you have to do inspections)
There's probably other stuff, but hopefully that'll get you started until others chime in.
Good luck and keep us updated.
Oh, check out the recent posts on dropping a SBC into your truck -- Very
YEP FIGURED THAT STUFF, I'M IN ILL. I WAS GOING TO GUT ALL THE EMISSIONS STUFF OUT WE DON'T GET CHECKED FOR THAT & ALOT OF IT IS
NOT IN A USABLE CONDITION(BEEN UNPLUGGEDDUE TO THE MOTOR SWITCH
OR ROTTED AWAY. I'M HANDY WITH A WELDER & DRILL PRESS IF SOMEONE
CAN GIVE ME A CARB MAKE MODEL ECT TO MATCH THAT MOTOR, I CAN
PROBABLY FIGURE THE REST OUT JUST DON'T WANT TO HAVE TO SPEND
MORE $$$ON 2 OR 3 CARBS BECAUSE THEY WERE TOO BIG OR TOO SMALL
THAT'S NOT A RETURNABLE ITEM AT THE PARTS STORE.
THAN-X FOR REPLYING JERRY
