» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Dec 21st, 2005, 01:44 PM   #1 (permalink)
JesseB.
More CLUTCH Problems...Please Help...
Hello, I have an 86.5 nissan 4x4, 4 banger... 142000. miles
I have replaced the clutch master, and the clutch slave, (both purchased from autozone) and I'm thinking, both aren't doing their job, because the
truck still has problems shifting smoothly...
Had a friend come over (who is a mechanic) he agreed with me that it
was just time to replace the clutch... SO, we tear into the thing..(which
is a big pain for you guys out there that have not done it yet)...
We get the clutch out and It's really in pretty good shape ( says Nissan
on it so im assuming it's the original) the plate was good minor wear...
so we proceeded to put a new clutch in it... 8 hours later, we have everything back together and wouldn't ya know it... SAME PROBLEM...
the damn thing wont go into gear...
I take the slave master back to autozone, and the guy tells me they gave
me the wrong part.... Put the new part on, it works alittle better, but
I'm still having problems with it going into gear smoothly...
( my mechanic friend said the shaft on the master slave dosen't seem to
be pushing out all the way... )
HERE'S my question, Is there any way to adjust the clutch master cyl.?
when I removed the original and replaced it with autozone copy,
I matched the rod length with the original...
Is there a chance the master isn't getting a complete stroke or shot
to the master slave, therefore, the slave rod isn't coming out all the way?
And yes, we've bled the hell out of the clutch.. Almost ran a quart of
dot 3 thru the system...
PLEASE ASSIST ASAP... Truck is in danger of being Shot with my 12 gauge...
I love the truck, but It will die if it no longer wants to Cooperate...
Thanks..
JesseB. is offline   Reply With Quote
Old Dec 22nd, 2005, 09:49 AM   #2 (permalink)
ddude2uc
It is very good practice to bench bleed the master cylinder before installing it. I've had to use plumpers tape on the hose that fits into the slave cylinder to keep it from leaking. (guess aftermarket parts don't fit good)
Anyhow, I've looked up under the dash where the pedal is at. From what I can tell, it looks like there is a nut up under there you can turn to adjust the travel of the rod going to the power booster.
I was going to mess with it untill I found a leak by the slave cylinder.
ddude2uc is offline   Reply With Quote
Old Dec 24th, 2005, 07:44 PM   #3 (permalink)
spat
Nissan Fanatic
Thanks..
yes the push rod on the pedal has an adjustabl length. Many people miss this and blame the parts store for the problem.
It's much easier to travel through a maze when you have a map!
Spat
Former Nissan Tech
14yrs ASE all but AT it's a bitXX!
New career - HandyMan/Electrician - Freedom at last!!
86.5 Nissan HB D21 234K Miles
94 Nissan Altima GXE ? Miles
97 Dodge Grand Caravan 3.8L 132K Miles
64 Chrysler 300-K 2-door Convertible 63K Miles
spat is offline   Reply With Quote
Old Dec 28th, 2005, 10:17 PM   #4 (permalink)
JesseB.
Thumbs up Clutch Problem Solved, Truck Gets To Live... Again..
I adjusted the rod coming from the clutch master, connecting to the pedal..
It now works like a dream... Furthermore, putting a bullet in the myth that
Hydraulic clutches aren't adjustable.. (I've been told that by people for
years) and I know, technically your not adjusting the clutch... just the
play in the pedal... and the amount of pressure to the clutch slave..
Thank's for all the assistance..Jesse.
Major Clutch Problem ( It has a mind of its own ) 86 NA BoBakTXL Z31 300ZX(T) 9 Nov 3rd, 2005 10:54 AM
clutch problems 240luvr S13 240SX 1989-1994 1 Dec 3rd, 2004 11:18 AM
post clutch install problems jeffinbham SR-Series Engines (DE/VE) 5 Mar 19th, 2004 05:42 PM
Clutch Problems. sliverstar Forced Induction & Nitrous Oxide 7 Mar 18th, 2004 08:15 PM
Clutch Problems Stevie_T_G GA16DE 1.6L Engine 7 Dec 18th, 2002 10:02 PM
