» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Dec 16th, 2005, 08:05 PM   #1 (permalink)
OnePhatCLK
Transmission problem
I just picked up a 94 nissan hardbody with 74k miles on it. It seems to have been very well taken care of. The problem after driving around for a bit and the car warms up it wont let me engage into first gear when at a complete stop and its hard to get it into second gear. When slowing to a stop i can get it into first gear. Also, how do i check the transmission oil in the truck.
OnePhatCLK is offline   Reply With Quote
Old Dec 17th, 2005, 12:33 AM   #2 (permalink)
Xeno
Nissan Addict
Manual?
From the sounds of it, and the milage, clutch might be failing.
The oil is filled from a plug on the side untill it reachs the top.
Xeno is offline   Reply With Quote
Old Dec 18th, 2005, 05:59 PM   #3 (permalink)
OnePhatCLK
Yes it is a manual. I heard about people haveing problems with it getting in gear when the car is cold. But after the driving the car for a bit is when the car wont go into first gear.
Old Dec 19th, 2005, 12:08 AM   #4 (permalink)
Xeno
Nissan Addict
Could also be the syncro gears failing.
Old Dec 19th, 2005, 03:01 PM   #5 (permalink)
Nissanpickup
Nissanpickup's Avatar
Send a message via Yahoo to Nissanpickup
A friend of mine had a manual nissan tranny problem and when he took it to the shop it was his syncros. Also his clutch was gojng bad
1991 nissan d21se vg30dett almost done pics soon after finished
Nissanpickup is offline   Reply With Quote
Old Dec 19th, 2005, 08:54 PM   #6 (permalink)
79kz400
Have you noticed a leak coming from under the vehicles cab?
79kz400 is offline   Reply With Quote
Old Dec 20th, 2005, 08:13 AM   #7 (permalink)
OnePhatCLK
yes, but i think its a oil leak.
Old Dec 21st, 2005, 05:49 PM   #8 (permalink)
79kz400
I ask because my tranny developed a hole in the case after the rear tranny crossmember rattled around loose for what was appearently a long time before i owned it. Gear oil is heavy and probably smells bad, especially dino oil. Inspect the leak for thick/smelly oil. Look under your truck just behind where the shifter is for fluid spatter/leaks. Look at the drive shaft where it hooks to the tranny.
I had problems shifting when my fluid got low. Check your tranny fluid. All you need is a 1/2" socket driver, a strong arm, and your finger to check for fluids. Download the FSM if you need to see diagrams. These FSM's are for the OBDII trucks but older models are physically similar.
Old Dec 24th, 2005, 07:45 PM   #9 (permalink)
OnePhatCLK
the clutch pedal is starting to make squeeking noises when i push it in or release it. Not sure if that has anything to do with the clutch being bad.
Old Dec 24th, 2005, 07:56 PM   #10 (permalink)
spat
Nissan Fanatic
did you check the fluid yet? could be getting hot due to lack of lubrication causing lots of problems. aside from a clutch not disengaging fully the syncronizers are the most common problem with shifting problems.
It's much easier to travel through a maze when you have a map!
Spat
Former Nissan Tech
14yrs ASE all but AT it's a bitXX!
New career - HandyMan/Electrician - Freedom at last!!
86.5 Nissan HB D21 234K Miles
94 Nissan Altima GXE ? Miles
97 Dodge Grand Caravan 3.8L 132K Miles
64 Chrysler 300-K 2-door Convertible 63K Miles
spat is offline   Reply With Quote
Old Dec 24th, 2005, 07:59 PM   #11 (permalink)
spat
Nissan Fanatic
you can even shift with out using the clutch at all if the syncronizers are in good shape and know the proper shift point.
Spat
Former Nissan Tech
Old Dec 24th, 2005, 09:02 PM   #12 (permalink)
OnePhatCLK
i havent checked the fluid yet i cant turn the bolt. That bolt it on there tighter then a SOB.
Old Dec 24th, 2005, 09:07 PM   #13 (permalink)
spat
Nissan Fanatic
if you are using a ratchet you can simply slip a length of pipe over the handle to get a lot more leverage.
Well good luck!
Spat
Former Nissan Tech
Old Dec 25th, 2005, 08:13 PM   #14 (permalink)
Vertigo1
Vertigo1's Avatar
get a torch and heat up AROUND the bolt, not the bolt itself... heat makes metal expand, I learned that in skool!!! hehehe
Serious, thats the only way I could get the drain and fill bolts out of the tranny in my '85 300zx. Lotta heat....
Dave Pretz
1995 Nissan D21 Ext. Cab V6 4wd
(Actually a '96 titled as a '95, wow was that a problem to get figured out!!!)
Vertigo1 is offline   Reply With Quote
Old Dec 25th, 2005, 10:59 PM   #15 (permalink)
jerryp58
Post Freak
jerryp58's Avatar
I wouldn't think so; my '04 with 11k miles has had a squeaky clutch pedal for a good while. Try some silicone spray or WD40 (works but is smelly) on the hinge points on the pedal.
Jerry
2004 Frontier, King Cab, XE, 4x1, 4-cyl, 5-spd
jerryp58 is offline   Reply With Quote
'92 transmission problem...(gone ?) mf915 Stanza 5 Apr 7th, 2005 04:33 PM
91 XE auto transmission problem ufa GA16DE 1.6L Engine 0 Oct 10th, 2004 12:30 AM
auto transmission problem HELP!!!!!! sr88 GA16DE 1.6L Engine 4 Jul 2nd, 2004 04:38 PM
96 Sentra Transmission Problem (Torque Converter Unlocking) Nick B14 95-99 chassis 0 Mar 19th, 2003 07:24 PM
Transmission Problem on a 93 Pathfinder nissanfan Truck & SUV 2 Dec 18th, 2002 06:23 PM
