» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV
Truck & SUV Armada, Frontier, Murano, Pathfinder, Quest, Titan, X-Trail, Xterra
Old Oct 6th, 2005, 10:15 AM   #1 (permalink)
90 4X4
Smile Need Help with Defroster & air flow
I have a 1990 Nissan 4X4 truck. The air works great, but only blows on the floor. It blows slightly through the air vents, but not at the defrost vents when I move the switch. Does anyone have any experience fixing this problem?
90 4X4 is offline   Reply With Quote
Old Oct 6th, 2005, 04:50 PM   #2 (permalink)
chuckb
my 88 does same thing.
chuckb is offline   Reply With Quote
Old Oct 6th, 2005, 08:48 PM   #3 (permalink)
mossman
Plastic mechanism on duct
I had the same prob, even worse. There is a plastic part on the duct flap/door mechanism. On the drivers side under the dash ofcourse, look at the duct system. You will see a flat plastic piece with the cable connected to it. It will also have a screw in the center. Remove the cable, cable clamp, and the screw holding the flap/door controller onto the duct. Look at the side of the flap controller nearest the duct you should see at nipple/stud protruding from the surface. There are actually a total of 3,and are visible unless they are broken off. Two of mine were!! Those studs are inserted into the flap actuator shafts (slots on the other plastic duct pieces) and they alll work together. I fixed mine with some shafts used for Photo Album Page refills (genious) by drilling a small hole exactly where the stud was and then "sandwiching" the plastic with 2 of the photo album shafts thus re-creating the broken studs. Then I reinstalled the whole mess, lubed it, and adjusted all the crap.
Sometimes you have to take the Bull by the tail and face the situation..........WC Fields
mossman is offline   Reply With Quote
Old Oct 7th, 2005, 09:32 AM   #4 (permalink)
90 4X4
Thanks for the info. I will try to fix it this weekend.
Mass Air Flow Sensor pathderaj Pathfinder 7 Sep 3rd, 2005 01:43 AM
air flow meter need help fast please WESIDA S13 240SX 1989-1994 0 Aug 16th, 2005 12:30 PM
diff mass air flow sensor WhiteHawk04 Forced Induction & Nitrous Oxide 2 May 2nd, 2004 10:52 AM
Air Flow Sensor/Meter SCUBAT General Maxima Discussion 4 Apr 29th, 2003 04:48 AM
High flow air intake? Zeus2k SR-Series Engines (DE/VE) 13 Apr 16th, 2003 03:58 PM
