Old Nov 27th, 2002, 12:19 AM   #1 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
Send a message via AIM to kbrassfi Send a message via MSN to kbrassfi Send a message via Yahoo to kbrassfi
rear brakes question
I have a noise that comes from my rear when I stop almost like a cliking noise, and I get a hum at high speed, not sure if is the bearings or my brakes, or maybe even the axle if anyone has any experience with this please let me know, because it getting annoying already, and I'm not sure how good it is for the car either. Please let me know also what pads are good for the drums in the rear for stopping and not heating up so much Thanks for all the help
Kirk
kbrassfi is offline   Reply With Quote
Old Nov 27th, 2002, 01:16 PM   #2 (permalink)
bobse007
Posts: n/a
Have your bearings checked out; more than likely it is bad.
Old Nov 27th, 2002, 01:33 PM   #3 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
Re: rear brakes question
Kirk
Do you have drilled rotors? They hum.
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Nov 27th, 2002, 02:08 PM   #4 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
NO, THEY'RE DRUMS IN THE BACK, AND ITS LIKE KNOCKING ALMOST WHEN I STOP, I'VE CHECKED AND I DON'T SEE ANY RUBBING, BUT AGAIN NOT SURE, THANKS FOR ANY HELP
Old Nov 27th, 2002, 02:21 PM   #5 (permalink)
sethwas
what?
sethwas's Avatar
Hey,
Its probably just your proportioning valve. It may be set too much in the rear.
Seth
my signature is at the bottom of this thread. its because its too long. Lots of important links there.
http://www.nissanforums.com/showthread.php?t=46259
sethwas is offline   Reply With Quote
Old Nov 27th, 2002, 02:58 PM   #6 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
THANKS GUYS, I'LL CHECK THE BEARINGS AND THE PROPORTIONING VALVE SEE IF EITHER ARE BAD OR WRONG, ANY IDEAS ON BETTER PADS OR ANYTHING? OR ARE CHOICES LIMITED?
My 96' 200sx
Old Nov 27th, 2002, 10:34 PM   #7 (permalink)
NastyNX2k
Send a message via AIM to NastyNX2k
I'm currently having the same problem with my rotors... just a suggestion: check the spring that is used when applying the ebrake... it not be strong enough to pull the drum brake off the drum.
1992 NX2000 Daily Driver
NastyNX2k is offline   Reply With Quote
Old Nov 29th, 2002, 08:39 PM   #8 (permalink)
V i V i D 200sx
Nissan Fanatic
V i V i D 200sx's Avatar
Send a message via AIM to V i V i D 200sx
i have that problem too! im not sure if its my brake pads needing replacement, and the assembly being too loose, or i heard its the strut bearing or somethin like that... also, my shock boot is all gone, so im sure thats not good either. im laggin on my car tho, i really dont wanna keep it. (i need an 200sx se-r!) but my experience is that it kinda does it every once in a while, mostly when coming to a slow stop, and also under heavy braking when going like 70+ mph on the freeway. (dont flame me for speeding, i dont care.) but that kinda seems opposite to me tho, that it would do it only coming to a slow stop, but also at high speeds, and not in between the extremes. anyone elses do this?
'95 200sx SE = konig divas on 185/60R-14 Kumho 716s, open-airbox, k&n filtercharger, 1.3 bar radiator cap, all red taillights, removed black doorframe vinyl, mesh grill, remote start alarm, no-chrome window frame, sylvania silverstars, optima red top, w/ 4AWG ground, full kenwood sound system. my car!
V i V i D 200sx is offline   Reply With Quote
Old Dec 7th, 2002, 10:00 AM   #9 (permalink)
JT200SX-N-FX
Hang out wit yo Wang out!
JT200SX-N-FX's Avatar
Send a message via AIM to JT200SX-N-FX
Lightbulb
Speaking of rear brakes, does anyone know about the release of the rear disc conversion for SE models. I know it was in the works, but haven't heard anything in a while.
Pics of my Ride!
http://mysite.verizon.net/vze1zp2e/units/jtstyle/
JT200SX-N-FX is offline   Reply With Quote
Old Dec 8th, 2002, 11:05 PM   #10 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
yea I've been gettin that clickin sound in the back when stopping too..
let us know if you fix it
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
