Old May 19th, 2005, 12:29 PM   #1 (permalink)
Vook
Help! Newbie needs advice (please)
I have a 2001 SE (B15), all stock with about 95,000 miles on it. My car is a Canadian model and there were 2 versions of the SE sold here.
My basic SE model included the 2.0L motor, larger tires (195/60-15) and some overall upgrades that made it a better performer over the 1.8L GXE.
(There was a "Sport" SE upgrade with 16" wheels and stiffer suspension that I passed on; this is a commuter/grocery getter only).
Recently, the front driver side strut has been noisy, like a bad creaky door hinge that needs a good shot of lube. Especially noticeable over things like speed bumps that force a decent amount of travel. I don't know suspension that well and I would appreciate some feedback on a diagnosis of the problem. I assume the struts are pooched anyway; just looking for some guidance on my options here:
So, do I:
1) replace with stock
2) attempt repair (feasible?)
3) aftermarket options for same height, spring rate, damping.
This is not intended to be a performance related enhancement. How difficult is it to swap out the struts?
Any help/comments would be appreciated. Thanks.
Vook is offline   Reply With Quote
Old May 20th, 2005, 02:49 PM   #2 (permalink)
Petrovich
Nissan Fanatic
Petrovich's Avatar
Send a message via AIM to Petrovich
Tried greasing them? Worked for my rears quite well. Get some nice grease (ask at a parts store, they should give you something good), raise the car on a jackstand, pull up strut's plastic/rubber boot, and put some grease on the metal tube thing. Let go of the boot. Lower the car back to the ground. Enjoy!
93 Sentra XE 5spd, running well... 82 924 Turbo under construction... 82 Suzuki GS650G, under construction... 76 Firebird Formula 5.7, waiting for the next summer.
Petrovich is offline   Reply With Quote
NEWBIE wish some advice georgecheng B14 95-99 chassis 2 Jul 16th, 2004 03:12 PM
Newbie Needs Advice on Buying 300ZX stinkyboy Z32 Chassis 300ZX 2 Jan 26th, 2004 07:50 PM
newbie shift advice (rpms, launches, heel/toe) drubin B13 91-94 chassis 10 May 28th, 2003 08:40 AM
Newbie needs advice Redsx S13 240SX 1989-1994 4 May 10th, 2003 12:07 AM
Newbie Here, Just Bought a 1996 Pickup, Need some Advice..! :) AndromedaSS Truck & SUV 4 Apr 20th, 2003 07:54 PM
