» Site Navigation
» Other Sites
» Network Links
Apr 11th, 2005, 12:13 PM
#1 (permalink )
drum brakes
need to kno how to remove and install drum brakes. if anyone can help me it would be greatly appreciated.
Apr 11th, 2005, 12:15 PM
#2 (permalink )
in^3,N20,RPM,PSI
For what car? Try to find the service manual and it will give you specific directions.
Apr 11th, 2005, 12:21 PM
#3 (permalink )
a 95 camry
Apr 11th, 2005, 12:25 PM
#4 (permalink )
in^3,N20,RPM,PSI
Well generally its all the same, you can take the drum off after removing the wheel by smacking it on the sides with a dead blow. Once the drum is off, you can see the bolts holding the assembly onto the backing plate and remove them.
Apr 11th, 2005, 01:57 PM
#5 (permalink )
thanks. respect
Apr 11th, 2005, 02:24 PM
#6 (permalink )
Big Hint!:
Only do one side at a time, that way you have a reference on how to put it back together.
Linear Mode
