Old Apr 5th, 2005, 08:37 PM   #1 (permalink)
svasica
When to replace OE pads/rotors/fluid? Stillen?
With normal driving, how long will the OE brake pads and rotors last on the car? I have 48K on the car, and am not sure if they were replaced already since I have had the car only for about 10K miles. The brakes are not the best since when I brake hard sometimes it feels like its fading, and starting to make alotta squeaking sounds! I was thinking of putting on the Stillen metal matrix pads, the Stillen cross drilled rotors, and the stainless steel lines. One question, is it really necessary to replace the rotors witht he cross drilled ones? Or will the stock rotors be fine with these pads?
svasica is offline   Reply With Quote
Old Apr 6th, 2005, 08:44 AM   #2 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
I would just get NAPA blank rotors (not cross-drilled, no slots). Even though cross drilled rotors are nice to have sometimes, you don't really need them per se.
OE Nissan pads last a while. If you want to see exactly how much pad there is left, take off one of your front wheels and check the brake pad thickness through the little window cut out of the caliper.
Captain Slow.
Old Apr 6th, 2005, 09:28 AM   #3 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
It depends on what 'normal' is for you. My wife drives her SUV 50 miles each way commuting to work. It is mostly highway, and the original pads are still good at 108,000 miles.
Routine maintenance on a car should include checking the brake pad thickness every 12,000 miles. The brake caliper has a slot to view the outer pad, and the inner pad is visible from the side. The pad should be replaced when the thickness is less than 1.5-2mm.
Lew
lshadoff is offline   Reply With Quote
1 bad caliper, have to replace both? sno Suspension & Brakes 4 Jun 22nd, 2004 10:02 AM
Im short on cash....can i just replace the boots of my driveshaft 3rdgenmaxima Dallas Nissan Enthusiasts 10 Apr 30th, 2004 05:36 PM
Stillen Intercooled Supercharger Passes C.A.R.B. 2FST4U Z33 350Z 2003+ 0 Dec 3rd, 2003 02:12 PM
Aug 9 Stillen Tour So Cal, ALL WELCOME. no_fuel Southwest 2 Aug 9th, 2003 08:42 AM
stillen exhaust black se r B15 2000-2006 1 Nov 1st, 2002 02:12 AM
