Old Feb 22nd, 2005, 08:22 PM   #1 (permalink)
SentGXE99
Powered by natural gas
SentGXE99's Avatar
NX2000 front brakes (ad22vf) on 99 Sentra GXE
The front brakes on my daily driver 99 Sentra GXE are way underpowered for daily beltway abuse, and highway to traffic jam cruising. The rotors, drums and pads were just replaced when I bought the car last May. One of my front rotors is already warped. I did a search for NX2000 brake swap. My car does not have abs. So do I need the Altima porportioning valve? Are the B13 and B14 front brakes ( spindles, hubs, calipers etc.) the same because a lot of swap info referred to the B13. Would a 2oo Sx SER front brake swap be beter, as what are the rotor sizes for the GA16DE, SE-R, and NX 2000? I would only be doing the front swap so would it go like the B13 swap info on the Nismo B13 brake upgrade guide? I want to go with stock brembo rotors and hi perf pads, no slots or holes. Fitted under 15'' SER wheels. Thanks for ANY help.-Chris
SentGXE99 is offline   Reply With Quote
Old Feb 22nd, 2005, 08:42 PM   #2 (permalink)
pete?
Banned
pete?'s Avatar
Send a message via AIM to pete?
all that you need to buy is this:
1. nx2000 1993 front brakes from the ABS car
2. nx2000 1993 front rotors from the ABS car
3. and tourque members.
pete? is offline   Reply With Quote
Old Feb 22nd, 2005, 08:53 PM   #3 (permalink)
himbo
Nis-ho
himbo's Avatar
what about the rears, cuz i'm thinking of doing a conversion
BACK TO GA16DE-T PROJECT... NEVERMIND... GOT SOMETHING ELSE ;-)
himbo is offline   Reply With Quote
Old Feb 22nd, 2005, 08:57 PM   #4 (permalink)
pete?
Banned
pete?'s Avatar
TQ members
93 ABS rotors
calipers from the 93 ABS car
Old Feb 23rd, 2005, 09:51 AM   #5 (permalink)
SXSENIS
Nissan Fanatic
if u have a 99 then your front bakes are the same as a ser's (b14). 91-97 ga16de has 9.1" x 18mm the ser's(and 98-99 ga's) are 9.8" x 18mm and the nx2ks are 10.1 x 26mm. The price difference is about 10-15 dallors more for loaded nx2k from a part store. Add matching rotors and your done 4 bout 250-300.
97 200SX SE
SXSENIS is offline   Reply With Quote
Old Feb 23rd, 2005, 07:48 PM   #6 (permalink)
SentGXE99
SentGXE99's Avatar
Ah, so for the B14 I don't need to swap knuckles or hubs, just calipers (or pads) , and rotors correct? What was this I read about the Altima porportioning valve? I am assuming since I don't have ABS or rear disc I do not need it, but expect slight pedal travel? Thanks for your help, I do appreciate it.
Old Feb 23rd, 2005, 11:12 PM   #7 (permalink)
wickedsr20
Red line chaser
wickedsr20's Avatar
Without a doubt, get a set of "loaded" calipers if you decide to go through with the brake upgrade. The loaded calipers come with the torque members. Only other thing to get is the AD22VF rotors and maybe stainless brake lines and good brake fluid for finishing touches. You will not need any type of proportioning valve with this upgrade at all, since the overall brake bias will not be changed that much. Just stronger stopping power and much better fade resistance when you hit the stop pedal.
96 SE-R: SR20VE - bolt ons
97 SE-R: SR20DET 54C - on hold - need $$$
03 Altima SE V6: PR CAI/SS grill/alarm & remote start/100 sf Stinger Roadkill/
19's (need tires)/stereo going in next
wickedsr20 is offline   Reply With Quote
Old Feb 24th, 2005, 12:18 AM   #8 (permalink)
SXSENIS
Nissan Fanatic
Loaded means caliper,mount bracket(torque member),and pads. you just have to remove the dust sheild and bolt on. and of couse the rotors. And he's right you don't need the alti master cylinder(proportioning valve) for this.
97 200SX SE
Old Feb 24th, 2005, 07:12 PM   #9 (permalink)
SentGXE99
SentGXE99's Avatar
Thanks!
Old Mar 28th, 2005, 07:31 PM   #10 (permalink)
SentGXE99
SentGXE99's Avatar
Alright, I went to try and order my calipers for the NX2000 for my 99 GXE sentra. They said I need to see if it was a US made car or Japanese car. Which caliper do I need the U.S. built one or Japanese built one for the upgrade? And do I really need the ABS calipers if I don't have ABS on my car?
Old Mar 28th, 2005, 08:49 PM   #11 (permalink)
pete?
Banned
pete?'s Avatar
you want the ABS calipers and rotors because they are much larger. as for the jap built or us built as far as i know it dosent matter at all.......they are all the same one is simply cheaper.
Old Mar 31st, 2005, 07:32 PM   #12 (permalink)
SentGXE99
SentGXE99's Avatar
Do the abs calipers have the solenoids and sensors for abs, and will it hook up to a non abs system?
Old Apr 3rd, 2005, 01:01 AM   #13 (permalink)
IanH
Post Freak
IanH's Avatar
You tell them its a Jap car, the NX's were all Japanese I believe. Anyway, I said Japanese and got the right parts.
Search for Part numbers, I posted my Raybestos part numbers, and there are other brand part numbers posted.
Good luck, also search for instructions, I cut and bent my dust shield, others cut it away.
Re: next post, the brakes were on an ABS nx2000 car, but there are no abs parts on my car or the brakes I installed. So no problem.
1997 S-ER 5 sp
2003 Pathfinder SE 4WD
1997 Sentra GXE .... SOLD
IanH is offline   Reply With Quote
Old Apr 7th, 2005, 12:02 PM   #14 (permalink)
maddnizmo
Send a message via MSN to maddnizmo
Is there a drilled or slotted rotors we can get for the adf's instead of some stock ones
maddnizmo is offline   Reply With Quote
Old Apr 7th, 2005, 03:07 PM   #15 (permalink)
maddnizmo
What I mean is there other options then powerstop/powerslot rotors
or any 4x100 10"5 rotors will do
front lip for a 99 sentra b14. nissanman22 Cosmetic Mods 13 Feb 10th, 2005 01:47 AM
Front brakes wearing extremely unevenly. nismoweapon B14 95-99 chassis 7 Oct 20th, 2004 03:23 PM
About to buy a '99 Nissan Sentra civic4982 B14 95-99 chassis 15 Jun 17th, 2004 05:14 PM
MAF adapter on 99 GXE SentGXE99 GA16DE 1.6L Engine 6 May 8th, 2004 02:55 PM
Big Brakes or NX2000 upgrade on my 91 Sentra XE? schauhan B13 91-94 chassis 2 May 3rd, 2004 02:12 AM
