You will have to unbolt the center bolt I believe its 30 mm and will require a breaker bar as it is torque around 100lbs also a pry bar wedge between the wheel studs will prevent it from spinning then if the drum doenst slide off you can screw some bolts into the holes in the sides that will pop it off
96 200sx with Erebuni 285 kit (GTR), 17" OZ superleggras, wilwood 4 pot 11" brakes, rear disc conversion ,lots suspension upgrades, hotshot header, stromung exhaust, CAI, UR pulley, JWT cams and ecu, racing seats, new carpet and rear seats a few other cosmetics sold car for 350Z
