Old Nov 16th, 2004, 03:44 PM   #1 (permalink)
Binger
USACI here I come
Binger's Avatar
Send a message via MSN to Binger
240SX "race" suspension parts
http://www.splparts.com/Parts/S13/Su...nk/default.asp
I've been looking at some of the parts on this site and have noticed that several manufactuers make these parts and they are becoming very common modifications on alot of 240s. Mostly on cars build for serious racing i.e. drifting, autox, drag racing.
Now my question is about the parts such as the tension rods, adjustable front lower arm, tie rod ends, adjustable rear upper arms, traction rods, rear toe arm, rear lower arm, Hicas eliminator.
I know that most of these parts are light weight tubing and very solidly built and designed to allow adjustability of suspension settings. As well as controll the side to side movment of the rear suspension. All this works together to provide a car with very tight handeling.
Does anyone have experience with the reliability of these pieces? Does the alingnment hold with these pieces? Do the "solid bearings" rather than the rubber or urethane bushings cause rough ride or excessive wear of the shocks and springs? Is it worth it? If you have any of these pieces what is your impression of them?
I'm buying a 240 to start working on soon and am researching wether or not this would be a good option for my suspension setup.
http://www.cardomain.com/memberpage/423794/1
When a grisly killing spree in Vancouver left 15 women dead, PETA tried to purchase full-page ads in local papers suggesting that this carnage was no worse than the killing of animals for food.
Binger is offline   Reply With Quote
Old Nov 16th, 2004, 04:08 PM   #2 (permalink)
Binger
USACI here I come
Binger's Avatar
Is it worth spending almost $3,500 on subframe parts? Then $1000-$2000 for shocks and springs?
Old Nov 17th, 2004, 06:46 PM   #3 (permalink)
Binger
USACI here I come
Binger's Avatar
bump...anyone
Old Nov 17th, 2004, 08:09 PM   #4 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
how did you get $3500 in subframe parts???
05 Frontier SE CC 4x4 (6spd)
Old Nov 18th, 2004, 12:09 AM   #5 (permalink)
Binger
USACI here I come
Binger's Avatar
SPL front endlinks S13/S14 $55
SPL rear stabilizer link S13 $199
SPL tension rods S13/Z32 $166
SPL pro front lower arm S13 $605
Adjustable tie rod ends -price not avaliable yet
Energy Suspension steering rack bushings $15
SPL pro rear upper arms S13/Z32 $307
SPL pro rear traction rods S13 $246
SPL pro rear toe arms S13 $250
SPL pro rear lower arms S13 $798
SPL pro Hicas eliminator S13 $432
SPL subframe bushing collars $88
SPL subframe tilt spacers $49
SPL pro aluminum subframe bushings $159
$3369
Figure tax and such it will probably be over 4000
Old Nov 18th, 2004, 12:12 AM   #6 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Are you building a race car or something getting all those parts?
Old Nov 18th, 2004, 12:13 PM   #7 (permalink)
Binger
USACI here I come
Binger's Avatar
I'm intrested in doing Auto X and some dragracing...but mostly will be a daily driver. I'm just wondering if these parts are worth it...and if they acclerate wear on the shocks and springs.
Old Nov 18th, 2004, 12:49 PM   #8 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
I don't think they'll accelerate wear on the shocks/springs but if its a daily driver i think it will create more NVH. I'm just putting in ES bushings in mine because I don't plan to race it and it beats the worn out bushings that are in there now.
Old Nov 19th, 2004, 01:44 PM   #9 (permalink)
futrsilviaman
They won't accelerate the wear and tear on your shocks and springs, but the spherical bearings and the heim joints may wear out because of excess road dirt and grime. I can't say how long the bearings will last. They will transmit much more road noise to the car though. Basically the ride won't be any stiffer, like you would get with increasing the spring rates of your car, but every seam, pothole, or irregularity in the road will definetely be palpable from inside the car. Will they be worth the money? That's up to you. Are you willing to compromise a great deal of ride quality for the pinnacle of performance. That's up to you. I know I would. They're a long way out for me, but I am definetely hoping that they'll be on my 240 one day.
You can also do the polyurethan bushing upgrade for the entire suspension, and then progressively buy SPL products for the suspension when you get the money.
futrsilviaman is offline   Reply With Quote
Old Nov 19th, 2004, 04:03 PM   #10 (permalink)
Binger
USACI here I come
Binger's Avatar
sounds good...and yes I am willing to sacrafice ride quality for performance...to an extent...I have a bad back so it can't be to harsh.
Superchargers and other missing parts BlackoutSpecV QR25 2.5L Engine 33 Dec 2nd, 2005 02:12 AM
Where to find high performance SE-R parts deStroyER B13 91-94 chassis 8 Oct 1st, 2004 01:03 PM
Need Help In Finding Parts For My Maxima 3rdgenmaxima Dallas Nissan Enthusiasts 0 Aug 26th, 2004 06:21 PM
No NISMO parts for us Afty L31 2002 - 2006 3 Nov 5th, 2002 01:56 PM
sidewall suspension sethwas B14 95-99 chassis 6 Jul 22nd, 2002 04:11 PM
