Originally Posted by Maximafan
I changed the rotors and pads on my 95 Maxima last year...and since then have been hearing grinding noises while braking just as the car comes to a stop. I pulled it all apart yesterday, cleaned it...everything looks fine, but the grinding noises continue.
Any ideas on what could be causing this?
Did you check the wheel bearings? I've found that more often than not, intermittent or low speed grinding noises are usually dirt in bearings.
The other thing that you may want to check is the clearance between the brake splash shields and the brake rotors. I know this sounds really stupid, but one of my friends' cars had this exact problem: The car was making horrible scraping noises and for a while, we had no idea why. It turned out that the shields had gotten bent somehow and parts of them were gouging the front rotors.
