Old Oct 19th, 2002, 12:47 AM   #1 (permalink)
snkee200sx
snkee200sx's Avatar
Send a message via AIM to snkee200sx Send a message via Yahoo to snkee200sx
rear disc conversion for 96 200sx se
i was wondering what is required when doing a rear disc conversion on an 96' 200sx?? i think that all i need is the control arms of of an se-r, the brake lines including e-brake lines. is there anything else that i might need to complete this swap?? i so let me now asap. any help is thanked in advanced.
mods... I/H/E, rota slips 15's c/f hood and slammed to the ground JDM for life!!!
snkee200sx is offline   Reply With Quote
Old Oct 20th, 2002, 03:15 PM   #2 (permalink)
SXSENIS
Nissan Fanatic
You need the whole rear beam assy. including the calipers and rotors. I've been looking into it also and you can pull one from a salvage car for around 200 bucks. The e-brake cable from the e-bake lever to the hubs. The brake lines can be discencted from the trailing arms to the frame and look like they would bolt right up. It just has to be from a 95-98 se-r or a 95-99 se{4 door 2.0l} but you'll still need the e-brake cable from a se-r. The 4 door model is slitly longer but can work as well with some creative routing to use up the inch or 2 of extra slack.
Their has been a few other post saying for better brake feel and balance to use a altima master cylinder from the same yrs.
Post your results please. Ive been scared to try it as of yet.{my car would be down for at least two days}I mean it doesn't sound or look that hard but their is always some issues that pop up, and I'd like to be preped for anything.
97 200SX SE
SXSENIS is offline   Reply With Quote
Old Oct 21st, 2002, 12:17 AM   #3 (permalink)
snkee200sx
snkee200sx's Avatar
as soon as i get a hold of some rear discs i will go on with the project, but i ran into a problem today. i totally trashed my front rotors today. i now have deep gouges in the rotor. i need to replace them so there's another setback on doing the rear disc conversion.
Old Oct 28th, 2002, 08:59 PM   #4 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
i am also looking into the rear disc conversion, getting sick of ye olde drums, so let us know......thanks......
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Oct 31st, 2002, 09:56 AM   #5 (permalink)
Zexel
Nissan Addict
Send a message via AIM to Zexel
Alright, well I have a B13 XE, and I plan on doing the NX swap. And I was wondering if when I were to do the NX front brakes if I could throw my front brakes from my B13 in the back for my rear disc. Hell I think it'd work if I wanted it to. I just really don't wanna run all the lines back there. It would work though right? Oh again, I've asked this like 100 times and never got like a straight forward answer, but if I did the NX front brake swap and got SS lines, which lines would I get? The NX lines so it could hook up to the caliper or Sentra lines so it would be the correct length and hook up to my feed. Or maybe Altima lines since I would use it's master cylinder? This just stumps me.
http://members.cardomain.com/zexel01
Zexel is offline   Reply With Quote
Old Nov 2nd, 2002, 01:21 AM   #6 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
thats a good question...but here is my thinking. you would be using the stock lines anyway wouldnt u? or would u be using nx lines? whichever rubber lines u use..id think you would use that model's stainless line.
Katana200sx is offline   Reply With Quote
Old Nov 2nd, 2002, 09:02 AM   #7 (permalink)
Yosho
Send a message via AIM to Yosho
Is there a difference in the size (diameter) of the lines? I know I hooked up my B13 SE-R's stock lines to the NX brake upgrade... so if I wanted to upgrade to SS lines, I would get B13 SS lines.
You're only changing out the flexible rubber brake lines with SS ones right? Not plumbing new hard brake lines? If so, I'm not sure why a Altima MS would make a difference if the inside diameter of the lines is the same... you'd only have to be concerned about the length of the lines and fortunatly there are B13 SS lines available to make it easy.
'93 Nissan 2000 GSR
'96 Nissan 200SX SE-R
'00 Honda Civic Si
Yosho is offline   Reply With Quote
Old Nov 13th, 2002, 12:40 AM   #8 (permalink)
JT200SX-N-FX
Hang out wit yo Wang out!
JT200SX-N-FX's Avatar
Send a message via AIM to JT200SX-N-FX
Arrow
I heard a couple of companies were making a rear conversion brake kit for us, is this still true?
Pics of my Ride!
http://mysite.verizon.net/vze1zp2e/units/jtstyle/
JT200SX-N-FX is offline   Reply With Quote
Old Nov 13th, 2002, 09:09 AM   #9 (permalink)
Katana200sx
P.O.S. Truckdriver
fastbrakes is working on one
Old Nov 13th, 2002, 10:54 AM   #10 (permalink)
JT200SX-N-FX
Thumbs up
OK, I thought so! If youre in a hurry, might as well do it now. If you have time to wait, The conversion kit will be simple i suppose. But I don't know what the price difference is.
Pics of my Ride!
