Old Oct 11th, 2004, 05:13 PM   #1 (permalink)
da_linkwent
Adjusting rear disc brake
I have a 1990 Sunny GTS (Japs), it has 4 disc brakes. Whenever i pull up the emergency brake only one side holds(left). You'll have to pull it all the way up for the other to hold. Which is not much help when parked on a grad. Could someone tell me how to correct this.
I was told that the brakes are self-adjust, is that true and if so what else could be the problem.
Got life insurance, now I need the money
da_linkwent is offline   Reply With Quote
Old Oct 11th, 2004, 07:22 PM   #2 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
Possibly one side is worn more than the other side. Have you replaced the rear pads lately?
Ninety-Nine SE-L is offline   Reply With Quote
Old Oct 11th, 2004, 11:15 PM   #3 (permalink)
da_linkwent
All 4 wheels. I thought that was the problem initially and I was told to change all 4s, so I did. Is it possible that the cable could be stretched out on one side? How would I check for this?
Old Oct 12th, 2004, 12:47 AM   #4 (permalink)
Ninety-Nine SE-L
Please Shift Here
could be, or the cable's not hooked up properly. try following the hard cable up to the e-brake.
Old Oct 12th, 2004, 11:02 PM   #5 (permalink)
da_linkwent
What should I look for? A break in the cable or something?
Old Oct 18th, 2004, 02:48 AM   #6 (permalink)
Asura
Send a message via MSN to Asura
check the E-brake balance bar.
none of the rear brakes drag, do they?
previous rides: 96 P10 (rolled over by friend in 1997), 93 S13 (front end totalled by friend on a canyon run in 1998), 84 AW11 (oil starved to death while loaned to friend in 1999)... guess people got problem with me.. lol
Asura is offline   Reply With Quote
Old Oct 22nd, 2004, 03:12 AM   #7 (permalink)
da_linkwent
Yes. I think it is the one thats not holdingg (right). I did check the cable and I dont find anything wrong with it (I found out that my stablizer link gone bad, good thing i got under there). Now the ultimate question ... where is or what is the balance bar?
Old Oct 22nd, 2004, 06:00 PM   #8 (permalink)
Ninety-Nine SE-L
Please Shift Here
underneath the car, right below the ebrake, there's a balance bar that splits 1 line into 2 lines. You will have to remove 1 of the heat shields to get to it.
it looks sorta like this:
Code:
            ____
            \ O \------------------
                   \_O_\-----------
rear drum to disc conversion Nissusan Suspension & Brakes 5 Jul 10th, 2004 05:52 PM
Rear Disc Swap....... vdubbub86 B11/B12/KN13 82-90 chassis 1 Aug 25th, 2003 11:59 PM
rear disc conversion? SXSENIS Suspension & Brakes 7 Apr 26th, 2003 11:14 PM
B14 Rear Disc Conversion Parts HawaiianSentra Suspension & Brakes 15 Aug 20th, 2002 11:15 AM
Rear brake swap ? Eric Suspension & Brakes 11 Jul 8th, 2002 04:30 PM
