Old Sep 29th, 2004, 11:54 AM   #1 (permalink)
Wyldstyle
Question Newbie: Needs Help with B14 Brakes!!
Hello All,
This college newbie needs help. I own a 1995 Nissan Sentra GXE, and I need new brakes. I took my car to the shop to get a quote on how much new front and rear (drum) brakes were going to cost. The estimate was 667.75!!
WOW!!! I was blown away!! So I have searched on this forum about Big Brake kits and NX2000 kits and "this and that kit" to were I am totally confussed. I figure if I have to pay 667 for new drum and fronts I might as well see if I could upgrade for the same price if not cheaper.
After reading about the kits, I still could not tell you if my GXE has ABS or not. So what should I do?? Should I just shall out the money for stock or try to upgrade the front and rears? Please keep in mind I have to do both now. Why? because I am running a minimum!!
I totally need help right now.....I am so lost. By the way if anyone knows of a better shop in Northern California (Bay Area) please advise?
Thanks everyone.
Nissan Sentra GXE
Year: 1995
HS CAI
16' Rota Sub Zeros
16' Yokohama AVS 100
UR Pulley
Wyldstyle is offline   Reply With Quote
Old Sep 29th, 2004, 12:08 PM   #2 (permalink)
LIUSPEED
Vendor
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
you can do an NX upgrade and get loaded calipers at autozone for 81.99 / pair + 93 dollar core charge but u can take your stock calipers off and give to them and get a refund back on the core.
also for the rear go to the junk yards and see if u can find a full 200sx se-r rear beam complete with everyting and might as well do a rear disc conversion .. im guesstimating that would be approx 100 bux or so at the junk yards
LIUSPEEDTUNING.COM Get your new headlights,corners here !!
Click here to get great quality HID's here for a really good price!!
LIUSPEED is offline   Reply With Quote
Old Sep 29th, 2004, 12:43 PM   #3 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
Send a message via MSN to Wufaded
Wow, $668 for brakes. Yeah I would also be checking out my options for that price. My advice to you:
1) Download the Sentra FSM and check out the brake section. Spend a little time becoming familiar with the brake system. Check out the front disc assembly and rear drum assembly drawings.
2) Do some more research on brake upgrades. Use "B14 brake upgrade", "rear disc conversion", and "AD22VF" in your searches and you'll come up with a wealth of information. There are many ways to accomplish the upgrade, by either getting the parts used or new. Keep in mind you might spend some time junkyard hunting or waiting for parts to be delivered.
3) Consider doing a "regular" brake job. By regular I meant buying new rotors and pads for the fronts, and new shoes and drums for the rears. Go to sites like Kragen , Autozone, or NAPA to get a rough estimate on how much this will cost. You can do this brake job from about $200-250 depending on what type of pads and shoes you buy.
If your calipers are good and your cylinders are not leaking, this is pretty much all you need to replace. You might even be able to save a couple of bucks if you can resurface your existing rotors and drums. If you got a written estimate of the $668 brake job, they might have listed what needed to be replaced. You might be able to use that as a guide.
Club MoFo Votary - My 200SX
Wufaded is offline   Reply With Quote
Old Sep 29th, 2004, 12:51 PM   #4 (permalink)
pete?
Banned
pete?'s Avatar
Send a message via AIM to pete?
wtf! $668 i have seen big brake kits for that much
pete? is offline   Reply With Quote
Old Sep 29th, 2004, 02:48 PM   #5 (permalink)
LIUSPEED
Vendor
LIUSPEED's Avatar
dude sent you an email i found a great deal for ya
Old Sep 29th, 2004, 06:06 PM   #6 (permalink)
pete?
Banned
pete?'s Avatar
share the wealth
Old Sep 30th, 2004, 04:21 PM   #7 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
Break that $668 quote down. What is he quoting you for?
Ninety-Nine SE-L is offline   Reply With Quote
Old Sep 30th, 2004, 05:37 PM   #8 (permalink)
Honest Bob
Traitor
Honest Bob's Avatar
Send a message via AIM to Honest Bob
Here is my thread from a while ago.
http://www.nissanforums.com/showthread.php?t=61814
RIP 1994 Nissan Sentra LE
1998 Nissan Sentra XE - Sold
1992 Nissan Sentra SE-R - Sold
2005 Subaru WRX Sport Wagon
Honest Bob is offline   Reply With Quote
Old Oct 1st, 2004, 03:14 AM   #9 (permalink)
Wyldstyle
Exclamation
$667.86 @ Big'O Tires in Vallejo for 1995 Nissan Sentra GXE will get you the following:
QTY.............Description....................... ...........Parts............Labor
1............... Disc Pads .................................. 71.30 ......... 60.00
1................Brake Fluid Disposal.......................................... 2.50
1................Reline Brake Shoes (LR/RR)............ 41.10 ......... 60.00
1................Brake Hardware Kit (LR/RR).............24.00
1................Brake Fluid Flush/ Bleed....................................29.95
1................(RF) SPEC:630.....ACT:632.............61.10...........1 5.00
1................(LF) SPEC:630.....ACT:641.............61.10...........1 5.00
1................(RR) SPEC:7.126..ACT:7.132...........78.30...........15 .00
1................(LR) SPEC:7.126..ACT:7.130...........78.30...........15 .00
1................Brake Kleen...................................5.00
Price for Front and Rear Brakes: $667.86
Old Oct 1st, 2004, 08:40 AM   #10 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
O'Reilly sells the front pads for $15.99 and the rear drums for $14.99 (rebuilt) and the hardware kit for $8.50. I don't know what the SPEC things are, but you don't need them.
They are not difficult to replace yourself.
Lew
lshadoff is offline   Reply With Quote
Old Oct 1st, 2004, 10:39 AM   #11 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
I'm guessing here, but I think the SPEC stands for the specified minimum thickness of the front rotors and rear drums. I know from memory that the MIN for the front rotor is .630 and the drums are 7.13. The ACT must stand for the actual measured thickness of the rotors and drums....too close to the min values, they can't be resurfaced, so he needs new rotors and drums.....
Old Oct 1st, 2004, 11:39 AM   #12 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
That sounds right to me, although I wouldn't trust them to assess whether they need resurfacing. They probably just do it every time. Also it appears that they are charging the cost for replacing rotors and drums from scratch even though they have to remove them to replace the pads/shoes which they are already charging for. It's double-dipping.
Anyway O'Reilly front rotors are $26.99/pair and rear drums are $43.99/pair.
Lew
Old Oct 1st, 2004, 12:55 PM   #13 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
Yeah I noticed the double-dipping also. If he was to do the work himself, he could save $400-500.....and that is including getting new rotors and drums, in addition to the pads and shoes.....extra cash for happy hour
Old Oct 1st, 2004, 03:02 PM   #14 (permalink)
Wyldstyle
Well I just order new NX2000 rotors and fully loaded calipers. What else will I need?
Old Oct 1st, 2004, 03:25 PM   #15 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
Check out this write up:
http://www.nissanperformancemag.com/...01/brake.shtml
newbie w/radio swap on B14? Bsentra14 Audio 5 May 11th, 2004 11:33 PM
Just looking.. and i think i have found something interesting for the B14 rear brakes Chuck Suspension & Brakes 4 Jan 14th, 2004 09:39 AM
What's up with B14 brakes? GA200 B14 95-99 chassis 33 Sep 3rd, 2003 02:37 AM
