Originally Posted by slow_sentra322
Again I bled the brakes. (By bleeding the brakes I let each line drip and pumped the pedal with the car on and with it off.) This time my brake pedal is goes to the floor.
To bleed the brakes you need two people. One person works the brake pedal and the other works the bleeder. The pedal person pumps the brakes slowly and then holds the pedal down and says, "Ready". Then the bleeder person briefly opens the bleeder (which has a transparent tube connected to a container with some brake fluid in it. This keeps air from getting into the system.). The bleeder person watches the fluid in the hose for bubbles while the bleeder is open. The bleeder person says, "Pump" after he has the bleeder closed. You do this again and again until several ounces of fluid are bled. The cycle should be repeated at least five times after bubbles are observed. The pedal person keeps checking the master cylinder reservoir to be sure it is full.
This procedure keeps air from entering the braking system when the brake pedal is lifted, and makes sure there is no air in the system.
The wheels for your car should be bled in the correct order: Right Rear > Left Front > Left Rear > Right Front. (It may be different for other models.)
Usually new master cylinders come with bleeder tubes which connect to the outlet ports. The ends of the tubes are run back to the reservoir. After the master cylinder is installed and the reservoir filled, the pedal is pumped until no more bubbles are seen. The tubes are removed, and the brake lines are then hooked up and the entire system bled
Lew
