Old Aug 29th, 2004, 12:30 AM   #1 (permalink)
NissanGirl2ooSX
Back away..slowly.
NissanGirl2ooSX's Avatar
Send a message via Yahoo to NissanGirl2ooSX
ABS light
You know what I searched and it hasnt helped me out so here goes..
Im buying a 300ZX..now the ABS light is on in the car and the guy said he got his brakes done one month ago..when I stop the car it stops but pulsates a bit. I dont know what the hell this could be, I heard it can be something minor like low brake fluid, the mechanic who did do the brakes forgot to bleed the lines, or bad rotors. Can it be something else? If I fix whatever the problem is will the ABS light come off? because when I did the O2 sensors in my car the light was still on..I had to reset the ECU. Any help would be appreciated, thanks.
Vroooom..
Tiburon: Garrett T3/T4 turbo, Equal length manifold, DSM Bov,Tial 38mm wastegate, FMIC, Fuel pressure modifier, DSM fuel pump, greddy turbo timer, autometer gauges, 2.5 inch custom exhaust, obx straight through muffler, high flow cat, obx underdrive pulley, kspec clear corners, cf altezzas, bsa lightweight rims + cooper high performance tires.
-=Alex 5-20-05=-
NissanGirl2ooSX is offline   Reply With Quote
Old Aug 29th, 2004, 12:41 AM   #2 (permalink)
BakaSama
SR20DE powered.
BakaSama's Avatar
Perhaps the ABS sensor on one of the wheels got misaligned or something
BakaSama is offline   Reply With Quote
Fuel Gauge and ABS Light aaronford Truck & SUV 0 May 19th, 2004 04:34 PM
Instrument Panel Light Jesse Bolt General Discussion 0 May 2nd, 2004 08:44 PM
ABS Light aaronford Truck & SUV 3 Apr 5th, 2004 10:32 PM
ABS light orion88 B13 91-94 chassis 1 Apr 1st, 2003 08:51 PM
CV joint install = ABS light??? orion88 B13 91-94 chassis 0 Nov 18th, 2002 10:42 PM
