My sentra 1.8gxe keep giving me some weird sound when and go over hump.
Its look likes that the rear suspension is not doing well, but I did drive it back to Nissan service center and manage to change both the rear suspension but still weird sound.
I been told by the Nissan service mechanical that not only my model, even Cerfero or other Nissan model have the same similar problem cause by the 'rear suspension bar'.
I really sad when I heard of that and regret to have a Nissan.
Did anyone of your guys have the similar weird thing?
sounds like you probably have your exhaust pipe hitting the axle.
i've never heard of anyone having problems with the rear beam.
Nope.
I didn't modify anything yet.
I did went back to Nissan service center last week. I ask the same technican to give me a test drive another nissan car to justify the problem. Hence, i manage to test drive the 2003 model.
IT IS THE SAME ! IT START TO SOUND WHEN YOU HIT THE HUMP AT 30 KM WITHOUT BRAKING.
maybe you have something loose in your trunk like your spare tire or something else?...i had wired sounds after lowering my car because the pipping i had done in the shop for my muffler was hitting the axle of the tire. i had the shop fix the angle of the pipe...no more sounds now...hope this helps....
I did remove everthing inside the trunk include the spare tire, tools ....etc....
before I went for a test.
