Old May 27th, 2004, 07:17 PM   #1 (permalink)
SR20dee
b15 pimp daddy
Send a message via AIM to SR20dee
geek question!!! brake angle
sorry if this is a repost for any one
I was wonder what the affects of seting up brake calipers at different particular axis's of the rotor does.
i note that alot of larger cars use the same calipers but at a different orientation.
such as a l31 altima and a b15 sentra..
does this affect force.... thoughts.. nerdyness.. engineers?
im curious as hell. id usually ask sarah but she said not to LOL
STAFF- www.b15sentra.net
kicking it sideways.. with cones please..
SR20dee is offline   Reply With Quote
Old May 27th, 2004, 08:38 PM   #2 (permalink)
Greg200SE-R
Nissan Fanatic
Greg200SE-R's Avatar
Send a message via AIM to Greg200SE-R
The pistons should provide the same force whether the calipers were centered at 10 o'clock, 2 o'clock or even at the bottom.
I would think that caliper size and clearance (between the brakes and suspension components for example) and things like brake line routing or mounting strength would influence caliper positions more.
Soundsl like Sarah has good brakes too.
Platinum Gold '98 200SX SE-R 17" Nippon Ver.5 AEM in/Tenzo R out Intake cam 17* Tein SS 336lb F+R w/pillowballs Progress rear sway bar Shigspeed LCA brace F/R strut bars H&R Trak+ Prothane/ES polys B&M SS/Nismo GT Ti JWT PP Stillen Type2 wing
________________
Greg200SE-R is offline   Reply With Quote
Old May 28th, 2004, 10:29 AM   #3 (permalink)
SR20dee
b15 pimp daddy
I will note one difference i note from being an experianced B15 owner.. the RTR world challenge car has the brake caliper between the 180 and 20 axxis.. why bother changing the the axis from its 90-180 axis postion??
Old May 31st, 2004, 07:11 PM   #4 (permalink)
SR20dee
b15 pimp daddy
BUMP! damn memorial day weekend
Old May 31st, 2004, 10:00 PM   #5 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Why not ask them?
The reasons that come to mind would be packaging (space constraints) and cooling. Depending on the car, it's easier to control the airflow over, under, and through the brakes when the caliper is positioned a certain way.
Captain Slow.
Old May 31st, 2004, 10:59 PM   #6 (permalink)
SR20dee
b15 pimp daddy
Originally Posted by ReVerm
Why not ask them?
I did... the pit guy's answer was lower center of gravity and its just alot easier to install that way LOL
I do like the notion you brought up about air flow.
Old May 31st, 2004, 11:04 PM   #7 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Haha. Hey, it all makes sense though, especially considering how much calipers weigh and the importance of ease of install/removal/replacement at the track.
Captain Slow.
Old Jun 1st, 2004, 12:31 AM   #8 (permalink)
SR20dee
b15 pimp daddy
yeah but the comment about lower center of gravity was ammusing simply becuase they are brembo calipers.. and should allready be light weight
but easier to get at in a jam is correct. from the looks of the lowering job.. it looks like it would be alot easier to get at from the bottom.
I still think there is something more to the angles on brake calipers.. SUVs usually have them on the back side or bottom. some cars have them on top.
thanks for your inputs man
Old Jun 1st, 2004, 12:23 PM   #9 (permalink)
SR20dee
b15 pimp daddy
bump happy tuesday
Old Jun 9th, 2004, 05:20 PM   #10 (permalink)
SR20dee
b15 pimp daddy
bump 1 week later.. is there any one worth a damn on this site?
Old Jun 9th, 2004, 06:35 PM   #11 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
If b15sentra.net was so good, you'd be asking there, no?
My Website, check it out!
Old Jun 9th, 2004, 08:18 PM   #12 (permalink)
SHigSpeed
No need to bump-bump! :^)
From a purely braking efficacy standpoint (not including heat dissipation concerns), the orientation of the caliper has no effect. However, for purposes such as center of gravity which has been mentioned as well as bleeding issues, it does make a difference. The bleed port has to be the highest part of the caliper or else there'd be no way to get all the air out hence most calipers (especially multi-piston jobbers) end up vertical either leading or trailing.
-SHig
SHigSpeed is offline   Reply With Quote
Old Jun 9th, 2004, 08:46 PM   #13 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
There is some advantage to them being behind the steering axis on the front wheels, it slightly helps the centering torque but the effect is very small on a car.
The main thing is that the bleeder screws be perfectly upright so the calipers can be bled effectivly, or to insure that the bleeder is at the highest part of the caliper.
Mike
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Jun 10th, 2004, 11:09 AM   #14 (permalink)
SHigSpeed
Mike
Mike,
How does the orientation of the caliper about the axis of the rotor affect steering centering torque? The caliper is essentially solid with the upright so I'm having a hard time visualizing how the location of the force path affects anything...
Thanks!
-SHig
Old Jun 10th, 2004, 02:10 PM   #15 (permalink)
SR20dee
b15 pimp daddy
now this is more like it
96 200sx se front disc brake question tdocz Suspension & Brakes 0 May 4th, 2004 01:45 AM
Brake question YANKEES General Discussion 1 Apr 15th, 2004 10:43 AM
Brake Booster Question udelslayer S13 240SX 1989-1994 0 Apr 9th, 2004 07:00 PM
Rear brake question kwd2kSE Z32 Chassis 300ZX 4 Mar 10th, 2004 01:14 PM
rear brake question viprdude Suspension & Brakes 7 Sep 20th, 2003 09:25 PM
