its times like this that make me wish I had a digicam haha lol.Anyways as for the install you need to jack up both sides of either the front or rear whichever you are working on bolt the endlinks to the swaybar.As for the front I am not sure exactly how it is attached but the rear I do know.The straight bolt end of the endlink goes up through the remaining hole on your strut right boelow the perch same goes for the other side.Pretty simple if you make sure you jack up both sides of the rear and let the wheels hang.
I See Someone Has A Bad Case Of The Hyundais.......................
