I recently bought and installed some KYB AGX on my car and at a solo event this weekend, I noticed that my car still had some body roll that was significant. I havent tried to put them to the highest settting yet, but I doubt it will resolve the body roll. The springs are OEM and all I have is a Vibrant STB. I ordered an active tuning RSTB and I hope it will help reduce the body roll. Howeverm, if I had to chose between Eibach pro-kit and suspension technique front and rear sway bars as a next mod, which should I go for. I've heard great things about the suspension technique sway bars about how flat the cornering was even with used near shot OEM struts.
GA16DE helped by intake, custom 2" 1/4 exhaust line, headers, unorthodox racing pulley, JWT ECU, JWT cams. And coming soon, KYG AGX struts, Eiback springs, suspension techniques front and rear sway bar, front and rear STB, goodridge brake line, drum to disc conversion for the rear brakes
the swaybars should eliminate the body roll. i am gonna get just the rear swaybar, cause if you put both, it will give abit much understeer.
That it was I thought. For the understeer, you can compensate by adjusting the sway bars, the suspension techniques are ajustable, or by playing around witht the setting on the AGX's, or by ajusting your tire pressure. Finally, a 1993 NX1600 in stock configuration as a tendandy to oversteer, so when you control for it, it gives a balanced feel to the car. Anyways, I spent yesterday doing a road course, skidpad and slalom and there are ways to adjust your car to be neutral, oversteer or understeer.
Thanks for the info.
I thought about buying a ground control coil over kit, but, well, for one thing they are pretty expensive and I dont really think I need to adjust my ride height. In any case, I will tune my suspension setup by gauging the tire pressure, the AGX's different ajustement, the suspension technique sway bar ajustements and my car's alignement. Anyways, I will be getting some Eibach pro-kit in a month or two.
Thanks for the links
GC's can be found for about $150 more than the Prokits..
Actually, setting the AGX's higher will reduce the amount of body roll. The damping adjustment system on those dampers primarily adjusts rebound, which is directly related to how much roll you'll feel.
You are correct in assuming that it won't eliminate the problem though. The stock springs are a bit too soft for that.
