Old May 15th, 2004, 10:10 AM   #1 (permalink)
mad dog
Question b14 front camber adjustable????
car lowered w/Eibach pro-kits ...alignment done and front camber shows -1.5 degrees of neg camber....Is this good for street and if not can this be adjusted on b14's????
mad dog is offline   Reply With Quote
Old May 15th, 2004, 10:31 AM   #2 (permalink)
Shawn
Surf
Shawn's Avatar
You'll probably wanna get a camber kit if the alignment was already done and thats the best that they could do. Otherwise you're tires will wear prematurely.
Sentra & F4
Shawn is offline   Reply With Quote
Old May 15th, 2004, 10:37 AM   #3 (permalink)
mad dog
so camber IS adjustable on front of B14??? correct??
Old May 15th, 2004, 10:40 AM   #4 (permalink)
Shawn
Surf
Shawn's Avatar
As far as I know it is, shouldn't they have took care of the camber when the alignment was done?
Don't quote me though, cause I could be wrong. Suspension isn't exactly my most knowledgable area
Sentra & F4
Old May 15th, 2004, 10:48 AM   #5 (permalink)
mad dog
shawn...thanks for help....you see the alignment guy told me that you cannot adjust front camber on these B14's...I thought that was just a little bit strange to me so thats why I am asking....I dont know if this is even within spec for this car but seems like a little too much neg camber to me unless you are road racing ....but, I have heard that some neg camber is also good for street but didn;t know how much .....hope I am making myself clear on this....thanks for responding and trying to help....
Old May 15th, 2004, 11:32 AM   #6 (permalink)
Junbug
Front camber is not adjustable. -1.5 isn't bad. I have a camber kit (tein) and it's dialed in for exactly that amount.
Jun
Junbug is offline   Reply With Quote
Old May 15th, 2004, 11:44 AM   #7 (permalink)
mad dog
Jun
Jun....thanks for this info.....thats exactly what I was looking for....so I should be ok with -1.5 neg camber...so I will not need a camber kit....
Old May 15th, 2004, 01:03 PM   #8 (permalink)
iron tomm
poster
Send a message via AIM to iron tomm
I have Teins also, and my camber was way off, somewhere around a -2.5 when we hooked it up to the machine. Didn't notice right away, so my two front tires were prematurely worn. I've since replaced the 2 front tires and purchased OBX Camber Bolts. Everything is good to go now. -1.5 Should be ok, but keep an eye out on the tires for any type of wear on the inside.
MOFO>YOU
iron tomm is offline   Reply With Quote
Old May 15th, 2004, 03:06 PM   #9 (permalink)
mad dog
thanks to all for info....will keep an eye for inside tire wear
mad dog
Old May 15th, 2004, 03:15 PM   #10 (permalink)
Junbug
Jun
You should keep an eye out on the wear though. As the suspension settled the camber went down to -1.7 still no uneven wear.
Watch it, usually the toe goes off whack every now and then which usually causes most of the wear. My car for some reason ends up going toe out over time. May look like camber wear, but usually is due to toe.
Jun
Old May 16th, 2004, 02:41 AM   #11 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
the alignment is mostly not adjustable. When you get an alignment, they usually jus adjust toe and bump parts around until it is stock, it's usually a very small adjustment. For major camber/caster adjustments, you can use lower camber pins (like I got) or find some camber plates.
Ninety-Nine SE-L is offline   Reply With Quote
Old May 16th, 2004, 08:08 AM   #12 (permalink)
Hendrix
What's in your wallet?
Hendrix's Avatar
Send a message via AIM to Hendrix Send a message via Yahoo to Hendrix
if you're at -1.5 and you don't want to buy tires sooner because of the uneven wear the camber bolts will do the trick for you. I found no benefit from having negative camber on a pure street car. the downside was the soft rubber compound on Z-rated tires disappeared quickly with the negative camber.
Hendrix
"Have you heard of the chain of command? It's the chain I beat you with until you realize that I'm in command" - Firefly, Jayne. Affirmative Action MoFo
Signature edited to please Scoot
Hendrix is offline   Reply With Quote
Old May 16th, 2004, 09:23 AM   #13 (permalink)
mad dog
If I go w/camber bolts...where do u get them???
thks,
mad dog
Old May 16th, 2004, 09:25 AM   #14 (permalink)
Hendrix
Hendrix's Avatar
check e-Bay for the camber bolts
Hendrix
Old May 16th, 2004, 09:26 AM   #15 (permalink)
biff
you will be fine. you can safely, without harming anything, run up to 3 degrees of negative camber on the street. i have had my car set at -3 for the last 2 years and never had a problem. just get your tires rotated on a regular basis, and you will be fine.
biff is offline   Reply With Quote
b14 Projector conversion for a B13 syndicate-bro B13 91-94 chassis 3 Jan 8th, 2005 01:36 AM
i hate brakecheck. advice on camber? Tickwomp Houston Nissan Enthusiasts 10 Feb 12th, 2004 05:42 PM
