mine started making weird clunking noises when I slow down to a stop. But that was after I hydroplaned into a concrete wall and bent both wheels on that side, soo...
Mine had clunking noises as well. It has transformed itself to a clicking while rolling and clucking while stopping. Kinda annoying to say the least. I thought I read about a TSR at some point but don't recall.
Clicking while rolling and clunking while stopping? You may want to take off the drum and look at the condition of the springs inside. It sounds a lot like a problem my mother's Quest had a while ago where a spring got mangled and the shoes were bouncing off the sides of the drum.
well, one more thing is to lubricate the contact pads on the drum backing plate where it makes contact with the shoes, this is a common problem when the lubricant dries off.
Awesome icon! Thanks for the suggestion. I'll pop the drum off this weekend.
Hmm... I don't think the springs are mangled, but definitely sounds like it could be one of the sources.
You guys rock. Looks like that was the problem. Had some noise from the springs too, so cleaned everything off and lubed it up and no problems.
