Old Mar 23rd, 2004, 10:42 AM   #1 (permalink)
Gibby
Front Strut Mounts. PLEASE HELP!!!!
Hey guys, I'm new here, but I've been on the maxima.org forums for a little while now, so I know a bit about how this works. I pulled about the stupidest stunt you've ever heard and now I'm in trouble.
I was working on the VERY simple task of installing a FSTB on my wifes '01 Sentra GXE. (Mechanically, I'm not a total idiot. I just installed FSTB, struts and lowering springs myself on my '95 Maxima last weekend w/out any problems) However, this was the first time I'd done anything with the Sentra. I got in a hurry and didn't research the proper torque settings for the strut mount bolts, and assumed they'd be just under those of the Maxima. I WAS WRONG!!!!
I set my torque wrench to about 28 ft/lbs (set my Max to about 35) and cranked away. I have a large/heavy wrench, so it really didn't provide any feedback and it felt like I was barely cranking when the bolt snapped off. :dumbass:
OMG was I p#ssed!!!! Anyway, turns out I had probably overtightened all the bolts, but only broke off one. Now I'm waiting for new mounts.
Here's the REALLY bad part. Nissan only has one and they are on indefinite backorder from the factory. I guess noone figured they'd wear out yet, or that an idiot like myself would break one.
The one mount is already on it's way to me now. However, since I overtightened the other side as well, I think it'd be safer to replace it as well.
Does anyone have any suggestions??? Are there any aftermarket mounts available? I haven't been able to find any. Are there any other mounts I can order that will fit (ie B14?)
Sorry for the long post. but I'm really up a creek here. Especially since it's my wife's car. Currently she's driving my Maxima (slightly scarey). We need to have both cars soon, and I need my Max. back.
Help please.
Gibby is offline   Reply With Quote
Old Mar 23rd, 2004, 04:20 PM   #2 (permalink)
jen@performance
Send a message via AIM to jen@performance Send a message via Yahoo to jen@performance
Which mount exactly did you need? I may have one in stock and if so I can ship it to you.
Performance Nissan Parts
(626)305-3000 Ext. 264
jen@performance is offline   Reply With Quote
Old Mar 23rd, 2004, 09:40 PM   #3 (permalink)
PHILLY-KID
PHILLY-KID's Avatar
Send a message via AIM to PHILLY-KID
Try a second Nissan dealer in your area. If they don't have it try 1stnissanparts.com link below. From teh homepage go to OEM parts, select your year and model. Go to front suspension assembly and it should be part #8.
https://www.trademotion.com/partloca...01&catalogid=1
1997 GXE - Euro Corners. Sidemarkers. Hotshot Header & CAI. KYB AGX's with Ground Control Coilovers. UR lightweight pulley, 17" Konig Gunmetal Imagines with Kumho 205/40R17's. PIAA 1400 foglights. Indiglo Gauges with the HVAC overlay. Pioneer DEH7400 Headunit with 6 disc changer. 6.5" Sony Xplod speakers. Stromung Catback Exhaust. Courtesy front and rear strut bars. Crystal Clear HID retrofit in progess with BMW 7 series D2S projectors.
PHILLY-KID is offline   Reply With Quote
Old Mar 25th, 2004, 09:38 AM   #4 (permalink)
Gibby
Hey, thanks guys.
I just replaced the one mount yesterday. the other one is still not in. My second mount seems pretty solid. I think I may have over reacted by ordering two. I did overtighten the nuts before, but apparently, it did no damage. I just torqued the nuts, removed them, and re-torqued them to 19 ft-lbs and they held perfectly, showing no signs of wear. The 2nd mount is still on backorder through my local Nissan dealer and since they had to special order it, I can't cancel it now. I'm not even sure I'll put it in when it comes. Oh, well. at least it's only about $16. Anyway, the project is done, just need to get it aligned. thanks for the suggestions anyway.
Old Mar 30th, 2004, 11:35 AM   #5 (permalink)
jen@performance
Originally Posted by Gibby
Hey, thanks guys.
You may want to call your local dealer and try to cancel the order. If it is still on back order with Nissan (not shipped from the warehouse to them yet) they should be able to cancel the order without penalty. They may have a small restocking fee of some sort to compensate their time, though.
Old Mar 31st, 2004, 10:23 PM   #6 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
You can buy front strut mounts from tirerack.com I believe
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Strut Bar for front soon2be B11/B12/KN13 82-90 chassis 4 Jul 6th, 2003 07:20 PM
B12-- The Difference Between Front Upper Strut Tower Bar & Front Upper Strut Bar? officialhb Suspension & Brakes 1 Apr 26th, 2003 02:16 PM
front strut bar bigsad B14 95-99 chassis 16 Aug 5th, 2002 11:13 PM
Do Upper strut mounts wear out easy? SentraBoy Suspension & Brakes 1 Jul 22nd, 2002 01:08 PM
