Old Sep 6th, 2002, 03:59 PM   #1 (permalink)
darius
Posts: n/a
Leaking brake fluid
Could any one help me on my problem? I changed my stock brake lines to steel braids and also my pads and shoes. My problem is now I'm leaking brake fluid somewhere. I can't see fluid leaking from anywhere.
Old Oct 1st, 2002, 10:57 PM   #2 (permalink)
93det
leaking
when you replaced the lines did you replace the copper washers. if so one should be above and one should be below the opening on the hose. if you did some new washers leak. sometime replacing the old washers solves this. other possibilities may be a worn wheel cylinder or a bad seal on a caliper. if you can give me a description as to roughly where the fluid is coming from maybe i can help you.
93det is offline   Reply With Quote
Old Oct 3rd, 2002, 02:58 PM   #3 (permalink)
darius
Posts: n/a
i can't realy tell were it's leaking from but every 2 days i have to put some fluid. i'm thinking of just replacing the wheel cylinders and calipers to start off with.
Old Oct 3rd, 2002, 08:57 PM   #4 (permalink)
93det
are the tires wet with brake fluid? you can also try filling it up and having someone pump the brakes while you look under the car.
tips on changing brake fluid sno Suspension & Brakes 4 Oct 5th, 2003 09:32 PM
brake fluid level problem minute rice sentra B11/B12/KN13 82-90 chassis 4 Jul 28th, 2003 07:28 PM
PS leaking, fluid everywhere B13xeBeater B13 91-94 chassis 4 May 3rd, 2003 06:39 AM
Bleeding brake fluid By Nature Suspension & Brakes 16 Apr 12th, 2003 02:22 PM
Master Cylinder Needed HawaiianSentra Suspension & Brakes 9 Aug 27th, 2002 04:43 AM
