Just wanna make sure I fine on everything for the rear drum to disk swap on my B13.
I have the following parts:
SE-R (B13)calipers, rotors, pads, spindles, e-brake lines and clips, ss brake lines, m/c. That should do it from what I've been told. Also I know that it most likely doesn't make a difference but does it matter if the spindles are from a SE-R with ABS? I know that it didn't with the NX2000 brake swap seeing as the calipers were ABS equipped. Also I got an NX2000 brake booster but it was the same as my stock booster. Thanks....
No it doesn't matter. I did the upgrade on my B13 and used the whole caliper assembly from a NX2K w/ ABS.
You got all the right parts. The brake booster isn't needed.
I also used my stock MC as well. It works ok, but has a little too much rear bias, but I took care of that by running Porterfield R4S pads on SE-R swapped front brakes and OEM pads on the rear.
__________________ 1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
Originally posted by Eric Just wanna make sure I fine on everything for the rear drum to disk swap on my B13.
Just a suggestion! Since you are doing a rear brake upgrade why not go with the Maxima rear caliper? A lot of us 91-93 SE-R owners are upgrading the rear to the Maxima rear brake.
I'd just hate to see you do the same job twice.
Edit: NX2000 rear brake will work as well. They are identical to the 89-94 Rear Maxima brake.
Will this setup work for the B14? I have a Sentra GXE and will do the SE-R beam axle conversion, but am still unsure as to what route to go for calipers and rotors. If the Maxima rear brakes are the same as the NX2K, then I will just do the NX2K front and rear brake upgrade. Any suggestions would be greatly appreciated.
Originally posted by Eric I believe that the Max's rear brakes are larger than the NX2000 front brakes making for a rear bias braking car. I perfer front bias myself.
Will the NX2K caliper and rotor system mount right onto my Sentra though?
Originally posted by LIUSPEED is it possible to change the 95 Sentra rear drums into disc brakes of a 200 SX ?
Hey,
You have the same car as I do. I also need some advice on changing my rear drums to disc. I plan to do the Nismo front upgrade with the NX2K parts, but want slightly bigger than SE-R parts on the rear. I have been reading that the NX2K rears are slightly bigger and some B13 owners have been using Maxima rears, but I want to you if they will just bolt on and what size are the calipers and rotors? The other question is which Master Cylinder do I use? The SE-R one or the one from the Altima? What are your plans for front and rear brakes?
I'm not sure about the NX2K rear brake but I do know that you can use the 95 and up Maxima rear brake for upgrade.
