Old Nov 2nd, 2003, 07:57 AM   #1 (permalink)
vashna
Send a message via ICQ to vashna
Question drum to disk brake conversion problem
Hi all, I got a used set of rear disc brakes from a scrap yard and installed it on my 1992 b13 sentra, but the brakes still do not hold as I think they should, am I missing something else in the installation ?? I got the whole hub setup and just swapped the drum ones with the disc ones . I got it with the handbrake cable so just removed the old one and installed the new one back in, everything was just a matter of swapping. If I drive at an average speed down my street and slam on the brake the wheels would not lock up for anything, instead the car would slowly come to a stop. with the rear drum the wheels would lock up and hold properly. Thanks for any info here guys.
Vash
vashna is offline   Reply With Quote
Old Nov 2nd, 2003, 10:50 AM   #2 (permalink)
Michael DeLoach
Make sure you bleed them really good. When I did my swap I also swapped in an Altima Mastercylinder and mine work great.
Michael DeLoach is offline   Reply With Quote
Old Nov 4th, 2003, 05:54 AM   #3 (permalink)
sno
**best avatar award**
sno's Avatar
i thought you needed to swap out the axles too. did you? and do what michael deloach said, bleed them really well and check your brake fluid level.
sno is offline   Reply With Quote
Old Nov 4th, 2003, 06:32 AM   #4 (permalink)
vashna
RE: Altima Master Cylinder
HI, is the altima master cylinder a direct fit on or is there any conversion/fabrication to do etc.........thanks. And I did bleed the brakes properly and made sure to top off the master cylinder with fluid.
Vashna
Old Nov 4th, 2003, 11:32 AM   #5 (permalink)
Michael DeLoach
Just bolt it up and go. It actually looks the same as the one on your car now. The Altima MC just has a larger inside bore and piston.
Old Nov 4th, 2003, 11:55 AM   #6 (permalink)
Sr2oFusIoN
Send a message via AIM to Sr2oFusIoN
hey call me up when you find a b13 with rear axles.. i have yet to see one
body kits, street glow, and altezza's arent going to make you fast..but if you wanna race with those mods.. let me go put on my shoes!!!
Sr2oFusIoN is offline   Reply With Quote
Old Nov 4th, 2003, 07:33 PM   #7 (permalink)
sno
sno's Avatar
well don't i i feel like a n00b.
Old Nov 9th, 2003, 10:44 PM   #8 (permalink)
maxpower559
Sentra E+Boost=WET PANTS
maxpower559's Avatar
Send a message via AIM to maxpower559 Send a message via Yahoo to maxpower559
ur going drum to disk. whenever i change the rotors and pads they seem to suck but after giving them a lil wearin with braking they work fine.
i did the rear drum to disk....i was a handbrake junkie...so when i noticed that the rear did grab right i was kinda bummed....then i wanted to put some life on them....i went 80mph on the freeway the my hand brake slightly pulled up(crazy...i know) and the next morning you found me drifting around turns like crazy again
AH HA! So they do make bigger diapers? That deceitful woman told me id have to learn to use the toilet. Well fie on the toilet! its made slaves of you all. ive seen it sitting there, lazy, slothful porcelain layabout feeding on other peoples Doo-Doos while contribution nothing to society! you get a job!!!!!
maxpower559 is offline   Reply With Quote
Old Dec 12th, 2007, 12:41 PM   #9 (permalink)
Rodriguez
Anyone could assist in finding a set of rear disc brake set for Nissan B13 -
1992? I live in Trinidad WI & it is difficult, practically impossible to find.
Rodriguez is offline   Reply With Quote
Old Jan 23rd, 2008, 03:38 AM   #10 (permalink)
lynchfourtwenty
this is good info, so when i swap the parts from my se-r to my xe, i am going to throw my agx's in also as well as the sway bar
dont you love the rush you get when your smoking a honda??
lynchfourtwenty is offline   Reply With Quote
Old May 20th, 2008, 09:28 PM   #11 (permalink)
slammed87d21
slammed87d21's Avatar
Send a message via Yahoo to slammed87d21
did you swap the master cylinder too?
1987 Nissan Hardbody Custom Convertible
1985 Yamaha FJ1100 Streetfighter
1988 Chevrolet C1500 Silverado
1991 Honda Civic Hatchback (Daily driver)
1979 Ford F100 (Met its maker at the crusher)
1982 Datsun 280ZX project car (R.I.P.)
1987 Nissan Hardbody XE 300ZX V6 swap (R.I.P.)
1985 Nissan 720 ST (R.I.P.)
1983 Nissan 720 (R.I.P.)
1983 Datsun 280ZX (R.I.P.)
slammed87d21 is offline   Reply With Quote
Old Jul 15th, 2008, 03:22 PM   #12 (permalink)
IanH
Post Freak
IanH's Avatar
You need to swap the master cylinder if you want more stopping power, the prop valving limits the pressure to a lower pressure on the Drum master cylinder.
1997 S-ER 5 sp
2003 Pathfinder SE 4WD
1997 Sentra GXE .... SOLD
IanH is offline   Reply With Quote
