Old Sep 16th, 2003, 12:57 PM   #1 (permalink)
98se-rNOS
Send a message via AIM to 98se-rNOS
Question brake rotors?
I've just bought some axxis ultimate brake pads and went to put them on and noticed just how badly scored the rotors are. I've already turned them once and don't think I could do it again, so I'm on the lookout for some rotors. I'd like cross drilled only because I've heard that the slotted wear out the pads quicker by acting like razor blades on them. Anyone know if this is true or not. Also..can anyone tell me where I can find cross drilled rotors for my 200...for cheap? Hoping to not spend over 250 for all four. Thanks!
Got NOS?
98se-rNOS is offline   Reply With Quote
Old Sep 16th, 2003, 01:28 PM   #2 (permalink)
bahearn
bitter old man
bahearn's Avatar
Cross-drilled are worse than slotted -- all those holes act like stress risers giving those rotors a tendency to crack. If you aren't racing, solid rotors will give you your best performance.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Sep 16th, 2003, 03:42 PM   #3 (permalink)
Wont Be Beat
Send a message via AIM to Wont Be Beat
Whats so good about slotted rotors? Please explain. I'd love to hear this.
Accordingly Done
Wont Be Beat is offline   Reply With Quote
Old Sep 17th, 2003, 11:23 AM   #4 (permalink)
pearsont74
Felix the Cat
pearsont74's Avatar
Send a message via AIM to pearsont74
i heard it helps cooling...
http://members.cardomain.com/pearsont74 Check my car out.
pearsont74 is offline   Reply With Quote
Old Sep 17th, 2003, 11:52 AM   #5 (permalink)
Wont Be Beat
How so?
And at the same time, what is so good about drilled rotors?
...as anyone that follows my posts can tell, I'm fucking fed up with hearsay.
Accordingly Done
Old Sep 17th, 2003, 03:35 PM   #6 (permalink)
PatScottAKA99XE
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
Slotted rotors are "pimp", X-drilled rotors are "pimp plus", and slotted/xdrilled are "pimp max".
Seriously though, can anybody find some independant test?
I am in no way an expert on this, but I would think slotted rotors would work well if they do infact(so they say) cut the pads a little more than normal rotors. To keep the pads from glazing. I would belive that slotted and x-drill rotors keep the pads from hydroplaning on there own gases, but 1. I thought modern pads didnt do that, 2. how noticeable is it when pads hydroplane, 3. is hydroplaning for real?
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
Old Sep 17th, 2003, 03:47 PM   #7 (permalink)
Wont Be Beat
Slotted rotors are usefull on rally cars and on car that see a lot of water.
If anyone wants opinions/facts of experts, let me know.
Accordingly Done
Old Sep 18th, 2003, 02:28 PM   #8 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Re: brake rotors?
Yeah, ultimates will do that. That's why I don't run them on the street. If you REALLY want drilled rotors and you have the stock brakes, you can get them for about 35/each +shipping at Nopionline. I'll stick to my $25 Autozone rotors though, thank you. : P
Captain Slow.
Old Sep 18th, 2003, 04:18 PM   #9 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
Send a message via AIM to Slayer2003 Send a message via Yahoo to Slayer2003
...if ya need info on what slotted/cross-drilled does for a rotor, how about emailing (edit)the company(/edit)? instead of starting a new argument on how their either geared twaord performance (wich they are) and not rice and just for looks.
either way ya go, there not for cooling. its to help vent the gas-buildup between the pads n rotors at high temps. the actual 'slots' on a rotor, are the vents running down the middle to dissapate heat. for normal everyday use, its pointless to get 'slotted' drilled, or the combo of the two, because you will never create the temperaturs high enough to make them work properly.
......$0.02
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
SEARCH BUTTON. USE IT OFTEN!
Slayer2003 is offline   Reply With Quote
Old Sep 18th, 2003, 05:52 PM   #10 (permalink)
Wont Be Beat
This is useless for the most part. Here's why: 95% of companies dont care about you. They care about making a profit and will make ambiguous claims to make you think their product is superior.
Unless you drive a rally car, or have $500 ceramic drilled rotors, they are NOT geared toward performance in any sense of the word.
Correction. It WAS to help vent gas buildup between the pad and the rotor. In the 1950's and 60's, the glue compound that held the pad material onto the pad backing plate would boil and "out-gas' causing a layer of gas to form between the pad and rotor. So unless you have a 1956 Chevy Bel-Air with stock brake pads, this is no longer an issue. Brake companies know this is not exactly common knowledge and use this to sell bogus products that do nothing but make them more money. Please reaslize this. Go find me any road racer using anything but blank rotors.
Please explain how this physics-defying feat is possible? How in the world can air be a better heat sink than cast iron? It cant. You are wrong. Slots dont dissipate heat. Slots help clean the leading edge of the pad.
Accordingly Done
Old Sep 18th, 2003, 06:00 PM   #11 (permalink)
PatScottAKA99XE
ex-Super *********
Sucks to be a ricer
EDIT- Should keep clean in the winter, right?
Patrick Scott
Old Sep 18th, 2003, 07:29 PM   #12 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
I think he was talking about the metal in the space between the two halves of a vented rotor. I'm not sure what to call them. Vent vanes?
Captain Slow.
Old Sep 18th, 2003, 08:21 PM   #13 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
......yes i was. i dont know what there called.
and like i said, this is now going to drag on and whatever anyone says will be turned down to matter of opinion. everyone was told a diff version of design properties of brake rotors, that is mine.
"Go find me any road racer using anything but blank rotors"
JGTC- http://www.motorsport.com/photos/sel...2&Y=2003&O=36#
....1st n 6th pic
for some reason i can 'see through' those rotors.......and i think those are pros......
http://www.motorsport.com/photos/sel.../Before_start#
...second pic.....oh look, slotted....i was looking for something on the subaru rally team, cause thats all they use, is drilled and slotted rotors.....
....keep looking on that site, then tell me that there not performance quality.
Old Sep 18th, 2003, 08:37 PM   #14 (permalink)
Wont Be Beat
There is no opinion when it comes to brakes. What you said was wrong. What I said was right. Just accept it, and dont waste time. Or keep arguing and Ill keep putting down what you say.
The rotors that those cars use are ceramic. Ceramic is a whole different beast. And rally is not road racing.
Accordingly Done
Old Sep 18th, 2003, 10:06 PM   #15 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
....i was using them for comparison. how the fuck you gonna tell me "Go find me any ROAD RACER using anything but blank rotors" when you know damn well all they would use is a ceramic-metallic compound. if you knew this was gonna come up, why would you even bring it up. now it seems you you are gonna put down everything i say on the matter, even when you just disagreed on what you said before.
anyway, im goin to bed. this isnt worth it anymore.
