First bleed, then bleed some more, aftewhich, bleed again. If that doesnt give you pedal pressure, then its your master cylinder.
But the easier way to check is turn off the car and pump the pedal. If you get pressure, then it just needs bleeding. If you dont, its your master cylinder.
