Old Sep 8th, 2003, 07:36 PM   #1 (permalink)
jjunior887
E-brake light problem after brake job
I just replaced the pads on my girlfriends 200sx and now the damn e-Brake light won't go out. Anyone have any suggestions as to what might cause it to stay on.
The e-brake does seem to release since I can turn the wheels fine with it off the ground.
The car has front and rear discs and the rears were a PITA since I didn't have the tool to screw in the pistons.
I ended up taking the whole caliper off the passenger side to get it loosen up. Any suggestions would be greatly appreciated. Thanks-James
jjunior887 is offline   Reply With Quote
Old Sep 8th, 2003, 07:48 PM   #2 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
Do the brakes seem to work OK?I would also look at the cables and make sure they are not binding and tripping the switch in the console or that you are alcking in pedal pressure.On some Nissans, the light will also go on if the brake fluid level is too low since they use a float in the master cylinder that tells it if the fluid is low.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Sep 8th, 2003, 07:57 PM   #3 (permalink)
jjunior887
I made sure the fluid level was okay so that rules that out, I guess a good look at the cable should be my next step. If it were binding enough to set off the light switch would the wheel still turn freely? For the most part it seems like the brakes work great, I did a flush on the brake fluid as well since I had to remove the one caliper anyway. That was a quick respose BTW, Thanks-James
Old Sep 8th, 2003, 11:58 PM   #4 (permalink)
Beltane70
Send a message via ICQ to Beltane70
Yes, the wheels could still turn freely even if the cable was binding enough to cause the light to light. My brake light will go on if I pull my brake handle up even a little bit.
Beltane70 is offline   Reply With Quote
Old Sep 9th, 2003, 11:39 AM   #5 (permalink)
dry
NF's Offical Post Whore
dry's Avatar
Send a message via ICQ to dry Send a message via AIM to dry Send a message via MSN to dry Send a message via Yahoo to dry
when i did my brakes I had the same thing happen... heres what I did, I made sure the fluid was full then jacked up the back of the car, took the ebrake off and spun the wheels by hand... I put it back down pulled the ebrake on, then let if off, then drove... about 5 minutes after driving the light went off and hasnt come back on, unless the ebrake is on. I dont really know what I did that fixed it (i really didnt do anything) but it hasnt been a problem and its been 2 months. -James
dry is offline   Reply With Quote
Old Sep 9th, 2003, 03:02 PM   #6 (permalink)
jjunior887
well the light went out by itself today, I didn't even get a chance to look it over. I'll let it go for now and see what happens. Thanks for the suggestions guys -James
