Old Sep 2nd, 2003, 11:35 AM   #1 (permalink)
diamond
Question help! squelling noise-but brake shoes are ok!
I have a 98 Altima GXE, with 72,00kms (42,000 miles) on it.
I get a harsh squeeling noise (not exactly the metal on metal squel when the brakes are worn out), but metal on metal nonetheless from one rear drum...
I happens mostly when I the car is just started (brakes are cold) and goes away, except when I brake hard.
I opened up the drum to have a look, but the brakes look like there in good shape (and w/ only 72,000 km I'd hope so)...
Any ideas what the problem is?
Thanks!
diamond is offline   Reply With Quote
Old Sep 2nd, 2003, 01:16 PM   #2 (permalink)
sethwas
what?
sethwas's Avatar
Could just be pad shimmy. Harmless but annoying.
Seth
my signature is at the bottom of this thread. its because its too long. Lots of important links there.
http://www.nissanforums.com/showthread.php?t=46259
sethwas is offline   Reply With Quote
Old Sep 2nd, 2003, 07:20 PM   #3 (permalink)
diamond
brake shimmy
is there any way to fix brake shimmy?
THANKS
Old Sep 6th, 2003, 09:45 PM   #4 (permalink)
Wont Be Beat
Send a message via AIM to Wont Be Beat
Some compounds just have a tendancy to squeel more often than other and differ at different stages of wear.
Accordingly Done
Wont Be Beat is offline   Reply With Quote
Old Sep 7th, 2003, 09:23 AM   #5 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
it could also be glazed shoes and drum, it might also help to resurface the shoes by getting rid of the glaze, or replacing them, or machining the drums, also check the brake hardware just in case.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Sep 10th, 2003, 12:54 AM   #6 (permalink)
Tickwomp
Industrial Design Lackey
Tickwomp's Avatar
Send a message via AIM to Tickwomp
im having a problem with the rear discs on my car. same thing, but when i looked at the back pads they looked fine. just replaced the front ones and so it has to be back. i tried installing new back pads, but i couldn't pump the brake fluid back into the reservoir to open the clamp thing (caliper?). i broke a C-clamp trying to close it, worked fine on the front ones.
Tickwomp is offline   Reply With Quote
Old Sep 11th, 2003, 10:56 AM   #7 (permalink)
Wont Be Beat
Open the fluid reserviour cap and use an old brake pad and a c-clamp or pusher tool to push the piston back in. If it is a a screw-type piston, it must be screwed in while pushed in.
Check this out... http://www.accordinglydone.com/tech.php?ID=76
Accordingly Done
Old Sep 11th, 2003, 10:58 AM   #8 (permalink)
whiteb14
Shift_AutoSE-R
whiteb14's Avatar
Send a message via AIM to whiteb14
thats the case i had... machining or replacing fixes the squeeling.
Dag D.
2004 Nissan Sentra SE-R
whiteb14 is offline   Reply With Quote
